Japanfanatic Posted September 25, 2011 Share Posted September 25, 2011 Hi Fellas! I am preparing my rear fog light conversion (according to this instruction: http://www.mkivsupra.net/vbb/showthread.php?80479-Fog-Light-Conversions-for-beginners ) by using an OEM MKIV rear fog light switch. The car doesn't have the plug connector fitted. I have to wire each pin on it's own. Does anyone have a pinout diagram for the switch or is anyone able to tell me which pin serves which purpose? There are 4 male connectors and two which seem to be female connectors. I believe you have a + and - connector and one for the signal? Thanks in advance:) Quote Link to comment Share on other sites More sharing options...
d_d Posted September 25, 2011 Share Posted September 25, 2011 Not sure about the answer to your question, but alot of people have recently bought this. http://www.mkivsupra.net/vbb/showthread.php?253183-Rear-Fog-light-PCB... Including me, made the job simple,quick,tidy Quote Link to comment Share on other sites More sharing options...
Japanfanatic Posted September 25, 2011 Author Share Posted September 25, 2011 But I still need to know which pin of the fog light switch is the on/off signal. Thanks anyway! Quote Link to comment Share on other sites More sharing options...
Nic Posted September 26, 2011 Share Posted September 26, 2011 Mawby did this conversion on his car, see thread HERE Quote Link to comment Share on other sites More sharing options...
RobUK Posted February 5, 2012 Share Posted February 5, 2012 Did you sort this? Quote Link to comment Share on other sites More sharing options...
ScottC Posted February 5, 2012 Share Posted February 5, 2012 I've just bought a UK switch from Keron, what do you need to know? Quote Link to comment Share on other sites More sharing options...
Pulley Posted February 5, 2012 Share Posted February 5, 2012 (edited) I've just done a full fog light oem switch and telltale light install, I am on my iPhone but can email thepinout of theswitch It's a "latching" switch Check my thread http://www.mkivsupra.net/vbb/showthread.php?262965-decided-to-wire-in-fog-switch-and-tell-tales Edited February 5, 2012 by Pulley (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted February 6, 2012 Share Posted February 6, 2012 84165-14010 is the part number for the rear fog light switch that was fitted to the UK Supra incase anyone needs it Quote Link to comment Share on other sites More sharing options...
RobUK Posted February 6, 2012 Share Posted February 6, 2012 Hi Scott/Pulley I have a UK Switch and the fog light conversion PCB's from Heckler and bascially I want to wire when up to work..... I have no problem in wiring the back end.... but the switch baffles me.... can someone tell me what wire goes to what pin and it's purpose (although I'm not too bothered abotut the purpose if it works I am also guessing that the switch can be wired to the rear light warning on the dashboard as I have seen this in a Post by Mawby...... Sorry if this sounds basic and stupid..... but I don't know and would really like to do this Thanks Rob Quote Link to comment Share on other sites More sharing options...
ScottC Posted February 6, 2012 Share Posted February 6, 2012 I know it's a poop drawing, this is what I wrote down when working out what pin is what for the fog switch. The light in the drawing is the backlight for the switch. HTH Quote Link to comment Share on other sites More sharing options...
RobUK Posted February 6, 2012 Share Posted February 6, 2012 Love it Scott, i'll have a look at how that "fits" in when i get home Cheers Quote Link to comment Share on other sites More sharing options...
RobUK Posted February 6, 2012 Share Posted February 6, 2012 Ok, I wonder if I have a different switch as I have 6 pins across the top of the plug end and 2 at the bottom... I have attached a picture not that is likely to help but thought it was worth a try.... Quote Link to comment Share on other sites More sharing options...
RobUK Posted February 6, 2012 Share Posted February 6, 2012 The Pins are marked on the pcb as - E FS LH HR B And the bottom row is + L Does this help? Quote Link to comment Share on other sites More sharing options...
Pulley Posted February 6, 2012 Share Posted February 6, 2012 I can't upload pic, but if youlook from the back of the switch, thetop leftand bottom right are + feed from sidelight , second from left top unused, 3rd 5th and 6th are common -, and bottom left is + output So pin 4 top from the left is unused also Quote Link to comment Share on other sites More sharing options...
ScottC Posted February 7, 2012 Share Posted February 7, 2012 (edited) Ok, I wonder if I have a different switch as I have 6 pins across the top of the plug end and 2 at the bottom... I have attached a picture not that is likely to help but thought it was worth a try.... Sorry Rob, I thought you was using a switch from a U.k spec. Mines the same as the picture in post one. Edited February 7, 2012 by ScottC (see edit history) Quote Link to comment Share on other sites More sharing options...
RobUK Posted February 7, 2012 Share Posted February 7, 2012 Sorry Rob, I thought you was using a switch from a U.k spec It's ok Scott, so did I..... I am guess it's a switch thats from Toyota thats from another car? Quote Link to comment Share on other sites More sharing options...
RobUK Posted February 7, 2012 Share Posted February 7, 2012 I can't upload pic, but if youlook from the back of the switch, thetop leftand bottom right are + feed from sidelight , second from left top unused, 3rd 5th and 6th are common -, and bottom left is + output So pin 4 top from the left is unused also Thanks for the reply and the PM, I think that actually makes done sense.... I'll have a look later. Cheers Quote Link to comment Share on other sites More sharing options...
ScottC Posted February 7, 2012 Share Posted February 7, 2012 It's ok Scott, so did I..... I am guess it's a switch thats from Toyota thats from another car? Ok. It should be easy enough to work out what the terminals are using a continuity tester Quote Link to comment Share on other sites More sharing options...
Pulley Posted February 10, 2012 Share Posted February 10, 2012 It's the sameswitch as I have in my Uk spec panel along with my headlight level an squirter switches I got from keron, it's also the exact same switch as in my yaris which helped me work out the wiring for it, I'm sure there must be variants tho Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted August 13, 2016 Share Posted August 13, 2016 Anyone figure out how to use the non latching switches? Quote Link to comment Share on other sites More sharing options...
