a98pmalcolm Posted September 25, 2011 Share Posted September 25, 2011 Hay all. Im selling my old wheels and someone from Sweden is asking if his brakes will fit my wheels. I think they will. He says there Euro brakes and I assume that the same as UK spec. Fronts Are: Lehrmeister 17 x 8.5" Split rim ET35 Offset 5 stud 114mm Stud Diameter Toyo Proxes TR1 235/45/17 Rears are: Lehrmeister 17 x9.5" Split rim with ET35 Offset 5 stud 114mm Stud Diameter Toyo Proxes TR1 265/40/17 Any advise would be great Thanks Paul Link to comment Share on other sites More sharing options...
Mario Posted September 25, 2011 Share Posted September 25, 2011 He says there Euro brakes and I assume that the same as UK spec. Paul true Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 25, 2011 Author Share Posted September 25, 2011 bumpski.. Link to comment Share on other sites More sharing options...
merckx Posted September 25, 2011 Share Posted September 25, 2011 Have you seen this drawing before, it's a cross section of the UK front brake and hub? Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 26, 2011 Author Share Posted September 26, 2011 so with it being 39.1 (i assume mm) would an offset of +35 be ok? Thanks Paul Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 26, 2011 Share Posted September 26, 2011 so with it being 39.1 (i assume mm) would an offset of +35 be ok? Thanks Paul No that doesn't follow at all. The only way to be SURE is try them, or find another owner you 100% trust who has these wheels on UK (Euro) brakes and will confirm there are no clearance issues. I suppose you could get someone to digitise the wheel and the drawing and tell from that, but it will be quite costly. Link to comment Share on other sites More sharing options...
merckx Posted September 26, 2011 Share Posted September 26, 2011 (edited) I suppose you could get someone to digitise the wheel and the drawing and tell from that, but it will be quite costly. Not really necessary as you can achieve the end result much easier. What's wrong with printing the above drawing full size (accurately), stick it to some cardboard, cut around the profile of the brake disc and caliper and hold it place to check clearances with the wheel. Obviously if the clearances were small it would be wiser to actually try a wheel in place or to speak to someone else who has the same wheels/fitment, but the above method will give you some idea how they'll fit. Edited September 26, 2011 by merckx (see edit history) Link to comment Share on other sites More sharing options...
bodilx6 Posted September 27, 2011 Share Posted September 27, 2011 How about just finding a near by member with UK brakes and stick one of your front wheels on there? I'll happily help, but I'm guessing Denmark is a bit far of.. Link to comment Share on other sites More sharing options...
