need advice
MySupra
im not looking to turbo my N/A but i am still going to make a effort with the engine
Would love to know what to get
Cams
pulleys
crank
drive shaft
prop shaft
and any think you guys think of
Thanks :D
Why not do a search and read up, otherwise im sure you may get offended by a few suggestions by people.
drive shaft ? propshaft ? crank ? why would you change any of these ?
spend you cash on giving it good service with new leads, cap, rotor arm, plugs, oil and filter, fuel filter, transmision fluid, diff fluid, check wheel bearings and all the bushes etc underneath.
check the brakes over and refurb them with new seals or even upgrade to the bigger 4 and 2 pots
you might find a bit of hp and torque with cams and vernier pulleys but nothing worth
shouting about.
get a decent exhaust and decatted, maybe even a nice manifold but your really chasing small gains
for the amount you have to spend
This gets asked far to much now, if you do a search you will find bud.
As said best thing you can do is get a decent service, suspension set up, brakes (up grade to uk spec if havnt already) and get a decent exhaust system and double de-cat. If your wanting more power your lookig at spending serious money for a decent gain! You would be cheaper to either drop a TT lump in it or just sell up and buy a TT.
That's just my 2p worth mate.
