vukelic Posted September 23, 2011 Share Posted September 23, 2011 Just recently i was driving my N/A 1995 Supra home night when I thought I heard a whirring noise. I listened for a bit more but it went away. Once i got home i noticed it was whirring when in neutral, just idling. it sounds like its coming from the front, kinda of near the clutch fluid reservoir. I am not super car savvy so i can't exactly locate it myself. I noticed however my car idles at around 1100 rpm, and thought maybe this was too high. Any ideas folks? Link to comment Share on other sites More sharing options...
vukelic Posted September 23, 2011 Author Share Posted September 23, 2011 Also it has about 66,000km. Link to comment Share on other sites More sharing options...
Swampy442 Posted September 23, 2011 Share Posted September 23, 2011 The idle is a bit high. When the car's idling turn the steering wheel, see if the noise gets louder. Might be the power steering pump Link to comment Share on other sites More sharing options...
vukelic Posted September 23, 2011 Author Share Posted September 23, 2011 So i tried the turning thing, and the sound doesn't really change however there is a really high pitched whine when the wheel is turned all the way, both ways. How can i lower my idle rpms as well? Link to comment Share on other sites More sharing options...
Konrad Posted September 24, 2011 Share Posted September 24, 2011 You can't, it should regulate itself. Did you have air conditioning on? Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 24, 2011 Share Posted September 24, 2011 (edited) Does the whirring stop if it's doing it idling in neutral and you depress the clutch pedal? If so it's worn out gearbox bearings. Never hold the steering against the stops, it loads up the power steering pump a great deal, and the whine is the pressure blow off valve opening. That bit sounds normal. Idling is ecu controlled, there'll be excess air entering the engine, almost certainly a mechanical problem,not an ecu one. Needs a good garage to look at it. Edited September 24, 2011 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
vukelic Posted September 24, 2011 Author Share Posted September 24, 2011 The air conditioning is not on. However i noticed that rpms dropped to about 700 after a few minutes. It doesn't seem to be only when it's in neutral. the noise kind of barely fluctuates when i press the clutch in and out. I noticed also the noise is not only in neutral and idling, i tried rolling along it first at about 1000 rpms and it still made the noise. Any other thoughts? Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 24, 2011 Share Posted September 24, 2011 If you feel confident in tackling it, remove the ancillary drive belt, the one that runs the air con, the water pump, alternator and PAS pump. See if that stops the whirring, but only run for a minute at the most, as the water pump is not turning with the belt off. If the noise goes it will be a bearing in one the things the belt drives, maybe the tensioner pulley for the belt. Link to comment Share on other sites More sharing options...
vukelic Posted September 24, 2011 Author Share Posted September 24, 2011 Well i may try that later, but the noise is really more underneath the console in the car, at least thats where is feels like it coming from. Close to the back of the engine. If this is also informative, i can feel a vibration increase in the shift stick and the e break. Around that area. Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 24, 2011 Share Posted September 24, 2011 Gear lever and handbrake area would suggest prop shaft joint or centre bearing, but that's obviously not turning in neutral Still think it sounds like a gearbox bearing. With the clutch fully depressed there's nothing else turning, when stationary in neutral, apart from from the flywheel and clutch cover / release bearing. The release bearing shouldn't be turning when in gear and driving. Link to comment Share on other sites More sharing options...
vukelic Posted September 24, 2011 Author Share Posted September 24, 2011 So if its a gearbox bearing, how bad is that to fix? Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 24, 2011 Share Posted September 24, 2011 If it's not really loud, live with it. If it IS really bad look for a good used box, a full rebuild will be several hundred pounds UK. Link to comment Share on other sites More sharing options...
vukelic Posted September 24, 2011 Author Share Posted September 24, 2011 Well if i do that, will it wreck anything in the car long term? Or what can i expect to happen over x number of years? Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 24, 2011 Share Posted September 24, 2011 Hard to say, it won't get any quieter, that's for sure, it may get a lot worse, quickly, it may stay much the same for tens of thousands of miles. Why not get a second, hands on, local opinion, and if it is just noisy gearbox bearings see how it goes for a few months, maybe keeping an eye out for a better box? Turn the radio up and stop worrying, unless pedestrians stop and stare I ignore anything that doesn't cause the car to deviate from my intended path, or cause actual flames Link to comment Share on other sites More sharing options...
vukelic Posted September 24, 2011 Author Share Posted September 24, 2011 haha alright sounds like good advice, we don't really have any good mechanics where I come from so it's tough getting a second local opinion. Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 24, 2011 Share Posted September 24, 2011 As I said, if it is a gearbox bearing, or bearings, the noise should cease completely just after you depress the clutch fully, with the car stationary, and in neutral. CERTAINLY, if you then put in a gear with the clutch still down it should stop, that will eliminate any clutch drag keeping the gearbox internals turning with the clutch depressed. Truck mechanics are usually good with gearbox problems and noises. Link to comment Share on other sites More sharing options...
vukelic Posted September 24, 2011 Author Share Posted September 24, 2011 I don't know if it changes anything, but when i turn A/C on the sound goes away, turn AC off, and it comes back, almost instantly. Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2011 Share Posted September 25, 2011 (edited) I would strongly suspect the bearing in the electromagnetic clutch of the air conditioning compressor. With the AC off this bearing is turning, with it turned on the clutch is electromagnetically engaged, and the bearing is NOT turning. Take the belt off, and turn the AC compressor pulley by hand. See if the bearing has play or feels / sounds rough. They can be replaced, in theory with special tools, in practice with some ingenuity. Bearing is indicated with a black arrow in the screenshot below. They can make a hell of a noise when they fail, I wouldn't have thought it would be felt at the gear lever or inside the car though. As a final test, do the "Tipex Test" on the crank damper, just out of interest.. Also, try spraying a little WD40 or similar on the inside and outside of the belt when it's making the noise, some makes of belt will make a racket when under a certain tension, the lubricant temporarily shuts it up. The cure is a new belt, ideally of a different make. http://www.mkivsupra.net/vbb/showthread.php?235358-Squel-on-Idle-Cold-Morningsl&highlight=tipex+test Edited September 25, 2011 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
David P Posted September 25, 2011 Share Posted September 25, 2011 You may find that a squib of aerosol grease will keep it happy in the short term till you find another. Link to comment Share on other sites More sharing options...
Konrad Posted September 25, 2011 Share Posted September 25, 2011 I think I have a airconditioning pump kicking around in the garage, if you will look for one Link to comment Share on other sites More sharing options...
vukelic Posted October 3, 2011 Author Share Posted October 3, 2011 if anyone was curious as to what it was, it was my pulley tightener, in the centre of the front of the motor. and my serpentine belt. Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 3, 2011 Share Posted October 3, 2011 Cheap fix then, could have been a LOT worse Link to comment Share on other sites More sharing options...
vukelic Posted October 3, 2011 Author Share Posted October 3, 2011 yeah, i'm pretty relieved. Link to comment Share on other sites More sharing options...
