Toyota Supra 1JZ GTE 2.5L 6 Cylinder 24v Turbo Cylinder Head / Valves / Cams / Covers
Guest chopperpaulc
Guest chopperpaulc
Genuine Toyota cylinder head / valves / cams / rocker cover / timing cover for Supra 1JZGTE TURBO.
As you can see in the pictures the parts are in good condition. These are designed for the 6 cylinder 2500cc 2.5L Turbo engine found in Mk3 Toyota Supra.
The head has been cleaned, skimmed and pressure tested. It has no faults and needs no repairs. All 24 valves are present but do not come with valve springs collets. The valve seats have been re-cut and ground in.
The cams, rocker cover and timing cover are all used but in good condition.
We see these heads used for the popular 1.5JZ conversion using a 2JZ 3.0L block.
£500 including P&P to the UK and Ireland
Feel free to PM me or call me at work on 02892612822.
Paul.
