Ryan.G Posted September 23, 2011 Share Posted September 23, 2011 Here is a chance to own a fully chassis rebuilt and track prepared Supra. Built in 2009/2010 by Autotec2004 and 2Bartuning (Ryan.g). The concept of this car was to make the Supra as light as possible in track based trim and completely balanced. To achieve this most of the original chassis was removed and rebuilt using lighter T45 (aircraft grade) chromoly tubing. Whilst rebuilding the chassis we decided that the engine could be moved back 15inches, which would make the supra as close as possible to being 50/50 weight distribution. The whole build was documented and posted below to see the level of care, safety and workmanship which was involved. http://www.mkivsupra.net/vbb/showthread.php?170424-Supra-Track-Car-Project I could talk for days about this car but its best to grab a seat and read the whole of the project. To summarise the build in pictures for those who don’t want to read the whole project thread see below. One black TT Stripped All Shell structures are lightened Mock up of engine fitment Chassis remade to suit engine placement Chassis Skinned in Aluminium Engine Mounts and Prop remade V Mount Rad and Intercooler setup made New Lightweight and collasable Nascar steering column made Ohlins Rebuilt by Chris Wilson Bonnet remade to suit V mount setup Chassis put on spit and primed Sprayed All sub frames strengthend Panels, suspension and brakes added Head rebuilt and worked by Swindon race engines Chassis all back together Engine back in and mapping Link to comment Share on other sites More sharing options...
Ryan.G Posted September 23, 2011 Author Share Posted September 23, 2011 Tilton pedal box added Car took to airfield for testing, setup and weighing Car as it looked in 2010 New turbo added and engine bay finished off Where all weight was lost in build we needed to add more downforce so wing and other aero parts added, Also replace roof scoop with carbon roof Flat floor was designed for more downforce and exhaust system was redesigned Engine Spec: 3.0 2JZGTE Full Race Head built by Swindon race engines – See build thread for more info HKS 264 Cams ARP Head Bolts New - Toyota Head Gasket, Oil pump, Water pump and full engine gasket set. Borg Warner 91/79 Turbo Custom Manifold and down pipe 50mm Tial V Band wastegate routed back into downpipe Custom air filter V Mounted Intercooler and Radiator with alloy expansion tank. Thermal protection intake manifold gasket 800cc PE Injectors RPS Lightened flywheel RPS Street Max Clutch -8 Braided fuel lines throughout Bosch 044 after swirl pot with walbros in tank for pickup Engine produces 600bhp and 550ftlb at 1.5bar. Can be tuned to 1.8bar on new owners request but 600bhp is more than enough to get used to car. Electronics: Syvecs S6GP with full knock: Wideband Knock Wideband Lambda Oil Pressure Oil Temp EGT Fuel Pressure Crankcase pressure Individual Wheels speeds Used for full traction control part of S6 2 x Cal switches for Changing engine power, traction level Race Technologies Dash2 Race Technologies DL1 Datalogger all link via can to dash and ecu Chassis: Tilton Pedal Box with braided lines throughout car Custom lightweight steering rack with NASCAR collapsible unit for safety Sparco Race Steering wheel with removable hub 4 Pot Front Brakes 6 Pot Rear KAD Brake Portford R4 Pads New Toyota Discs Titon Anti roll bars Ohlins 2 way adjustable suspension Custom built 40litre fuel tank with external swirl pot and Bosch 044 pumps Full GT Carbon Wing Full Alu Flat floor with custom diffuser Cobra Bucket seats with TRS Harnesses Custom Front F40 Splitter Toyota OEM Sideskirts and Spats Complete alu flat floot Enkei Light wheels with R888 Lexan Windows Front and Rear tow points Carbon Roof And much more which i just cant think of!! Car is priced at £25,000 Link to comment Share on other sites More sharing options...
staples230uk Posted September 23, 2011 Share Posted September 23, 2011 Wow, that is an amazing car and I really wish I had the £25k to buy it! GLWTS! Link to comment Share on other sites More sharing options...
Westy Posted September 23, 2011 Share Posted September 23, 2011 Amazing car...if only!!! GLWS Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted September 23, 2011 Share Posted September 23, 2011 only in my wettest of wet dreams. truly amazing, would love this. Link to comment Share on other sites More sharing options...
Ryan.G Posted September 23, 2011 Author Share Posted September 23, 2011 Forgot to say this car is FULLY ROAD LEGAL AND HAS MOT Link to comment Share on other sites More sharing options...
lockys96 Posted September 23, 2011 Share Posted September 23, 2011 good luck, i can see this one heading over the pond Link to comment Share on other sites More sharing options...
Abz Posted September 23, 2011 Share Posted September 23, 2011 Forgot to say this car is FULLY ROAD LEGAL AND HAS MOT That is just insane! This is the ultimate track machine! I saw this at a Wheels Of Motion meet, it is a stunning machine Ryan, do you know what the power to weight ratio is? Link to comment Share on other sites More sharing options...
EMPEROR Posted September 24, 2011 Share Posted September 24, 2011 Really insane car!!! Wish I had the money! Wouldn't think twice! Good luck with the sale man! Link to comment Share on other sites More sharing options...
imi Posted September 24, 2011 Share Posted September 24, 2011 Love the creativity & determination Ryan - good luck with the sale. Link to comment Share on other sites More sharing options...
Bailey. Posted September 24, 2011 Share Posted September 24, 2011 Where did this come from!!!! That is a stunning bit of work there Ryan, good luck with th sale mate. Link to comment Share on other sites More sharing options...
bignum Posted September 24, 2011 Share Posted September 24, 2011 Alot of car/performance for 25k, i`m filling my lottery ticket out now:eyebrows: Link to comment Share on other sites More sharing options...
Scott Posted September 24, 2011 Share Posted September 24, 2011 That is just insane! This is the ultimate track machine! I saw this at a Wheels Of Motion meet, it is a stunning machine Ryan, do you know what the power to weight ratio is? Give or take 600/1.250 Link to comment Share on other sites More sharing options...
ManwithSupra Posted September 24, 2011 Share Posted September 24, 2011 Hi mate, would like to come and see this. Can the flat floor be removed fairly easily for any work to be carried out? Link to comment Share on other sites More sharing options...
Wez Posted September 25, 2011 Share Posted September 25, 2011 Good luck with the sale matey, a shame your selling This is a real track machine and feels like no other MKIV I have been in, if I had the spare cash I would snap it up Link to comment Share on other sites More sharing options...
j_jza80 Posted September 25, 2011 Share Posted September 25, 2011 The spoiler is a Voltex type III. http://www.evasivemotorsports.com/merchant2/merchant.mvc?Screen=PROD&Product_Code=VOLTEX-GT-WING-3&Category_Code=VOLTEX_WING A retro fit Gurney flap is available for it too. Link to comment Share on other sites More sharing options...
adnanshah247 Posted September 25, 2011 Share Posted September 25, 2011 awesome machine, as far value for money, ryan your nuts selling at that price, anybody trying to build this car from scratch will end up paying 4 times as much! truely one off machine and im pretty sure one lucky buyer will come along fast! Link to comment Share on other sites More sharing options...
TT Paul Posted September 27, 2011 Share Posted September 27, 2011 saw the mag feature this is a great feet of engineering, good car ive seen ryan a few times and have seen what he can do this tops it so far.. Link to comment Share on other sites More sharing options...
Supra-Brett Posted September 27, 2011 Share Posted September 27, 2011 euromillions ticket purchased and money will be with you as soon as I win:) Link to comment Share on other sites More sharing options...
ManwithSupra Posted October 9, 2011 Share Posted October 9, 2011 Went to see this for the second time today you really cannot believe the amount of care and hard work that went into making this car, its really something to see in the flesh. So the upshot? Well i couldn't walk away without putting down a deposit on it could I Link to comment Share on other sites More sharing options...
Scott Posted October 9, 2011 Share Posted October 9, 2011 Well done mate, bet you can't wait Link to comment Share on other sites More sharing options...
Havard Posted October 9, 2011 Share Posted October 9, 2011 Well done Richard. That is a lot of car for £25K...!! Link to comment Share on other sites More sharing options...
JamieP Posted October 9, 2011 Share Posted October 9, 2011 Nice buy Richard, hopefully see it at some meets next year. Link to comment Share on other sites More sharing options...
johnny g Posted October 9, 2011 Share Posted October 9, 2011 As above. You've bought a truly unique car. Link to comment Share on other sites More sharing options...
Bailey. Posted October 9, 2011 Share Posted October 9, 2011 At least it has gone to a club member and not to europe never to be seen again like so many, congrats... Link to comment Share on other sites More sharing options...
