crispy Posted September 22, 2011 Share Posted September 22, 2011 hi all need some input if anyonecan help? doing an n/a to tt conversion at the same time as an auto to r154 box (5 spd) all is runnnig but gear changes very notchy not very smooth do i need to uprate or change any bits, there is a possibility that the slave cylinder piston is not long enough to dissengage the clutch properly if anyone is out there who has done this conversion or just knows wat are issue may be some info/advice would be greatfull regards chris Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted September 22, 2011 Share Posted September 22, 2011 Hi Chris All 3 of the boxes I've got / had were notchy, not as bad as the V160/V161, but definately nowhere near as smooth as the W58. If you'r car goes into the gears fine at standstil with the engine running, I cant see your clutch being the issue. If it was dragging, you would struggle to select the gears. Perhaps a video of the notch box in operation would help us say "yeh thats normal", or "no thats fecked". Ben Quote Link to comment Share on other sites More sharing options...
crispy Posted September 22, 2011 Author Share Posted September 22, 2011 unfortunatly cant get a video as its at a garage not all that accessable to me atm! aparently it goes through gears 1-5 notchy but struggles reverse ! clutch brand new exedy hyper single plate, have been told it may be master cylinder? apparently theres three different types and because it was an n/a we replaced it with a tt one and tt servo i cant see wat difference it would make! give it ago tho i guess did you convert any of your cars to manual ? if so can you remember ever changing slave cylinder piston for a longer one ? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 22, 2011 Share Posted September 22, 2011 What was the box from, Mk3 Sup? Soarer/Chaser? If its a Mk3 and the extension has been fabbed maybe thats slightly out of alignment? Soarer box with the cradle, maybe the bushes are worn? Why would you need a longer slave cylinder btw Quote Link to comment Share on other sites More sharing options...
crispy Posted September 23, 2011 Author Share Posted September 23, 2011 were going to try an actual tt clutch pedal as someone has put a jz80 clutch pedal inn and apparently there different. Quote Link to comment Share on other sites More sharing options...
crispy Posted September 23, 2011 Author Share Posted September 23, 2011 were going to try an actual tt clutch pedal as someone has put a jz80 clutch pedal inn and apparently there different. owe and yes it was from a soarer with the 1jx bits required. Quote Link to comment Share on other sites More sharing options...
