a98pmalcolm Posted September 21, 2011 Share Posted September 21, 2011 Anyone know if there is an aero wiper conversion for the supra? New wiper arms, wiper blades the whole kit? Not just aero wiper style that goes on the standard arm that you can get from Halfords! Did it on my Corrado. Was a great upgrade.. Thanks Paul Quote Link to comment Share on other sites More sharing options...
spikedjack Posted September 21, 2011 Share Posted September 21, 2011 depends if a car has the same arm/blade length as the supra i guess, aero blades dont just have one fitting you see, there are many many types unlike the conventional hook type fitting used on regular blades... i'd probably just use the retrofit sort if it were me Quote Link to comment Share on other sites More sharing options...
hodge Posted September 21, 2011 Share Posted September 21, 2011 What's an aero wiper Quote Link to comment Share on other sites More sharing options...
spikedjack Posted September 21, 2011 Share Posted September 21, 2011 One of those hodge, they wipe much cleaner than conventional blades due to higher contact areas, and look more modern Quote Link to comment Share on other sites More sharing options...
Guigsy Posted September 21, 2011 Share Posted September 21, 2011 You don't mere a whole different wiper arm. It's just a blade design. Fitting a different arm would be pointles. I use them they are great. I've got some from the states with rainx impregnated rubber Quote Link to comment Share on other sites More sharing options...
Lee_e Posted September 21, 2011 Share Posted September 21, 2011 They look good and work great untill I go over 70mph.. then they get weird and dont wipe certain parts of the windscreen and it goes all glitchy. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 22, 2011 Author Share Posted September 22, 2011 (edited) The reason for me wanting to change is, yes its modern and wipes well but more importantly loads of paint is flaking off and my wiper arms look dead awful, and also on arm wont hook and clip in a wiper properly.. Maybe if the arm fittings are the same as a Lexus IS200 or something.. Edited September 22, 2011 by a98pmalcolm (see edit history) Quote Link to comment Share on other sites More sharing options...
Abz Posted September 22, 2011 Share Posted September 22, 2011 I am not sure about replacement arm but like Guigsy I just brought the aero wipers which replace the whole blade so it looks much more modern & actually wipes quite good too. If the paint is flaking off then it would be best to repaint the arm? Or replace if you mean it's faulty. Quote Link to comment Share on other sites More sharing options...
Scott Posted September 22, 2011 Share Posted September 22, 2011 I am not sure about replacement arm but like Guigsy I just brought the aero wipers which replace the whole blade so it looks much more modern & actually wipes quite good too. If the paint is flaking off then it would be best to repaint the arm? Or replace if you mean it's faulty. Where did you bring them to? I have Aero blades on mine, the spring on the drivers arm has lost a bit of tension though so I think I'll need to replace the lot of it soon. Quote Link to comment Share on other sites More sharing options...
Noz Posted September 22, 2011 Share Posted September 22, 2011 I also have Aero blades on mine. I want to be like Scott. Im not nearly as cool though. The one thing I'll say, is some of them have BIG ass connectors. The clip on each blade is mooo'sive compared to a typical blade. I'll take a photo later. Not 100% if all are like this though, maybe uber-cool Scott would take a photo of his Quote Link to comment Share on other sites More sharing options...
Guigsy Posted September 22, 2011 Share Posted September 22, 2011 The arm is easy enough to take off. Just one bolt. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 22, 2011 Author Share Posted September 22, 2011 Looks like i may just replace the oem arms for oem again as the wipers dont click in properly. i'll do the rear one at the same time. I think u and scott should hook up noz lol Quote Link to comment Share on other sites More sharing options...
