TimH Posted July 17, 2005 Share Posted July 17, 2005 Ok, I'm not having a good run of luck recently.... I drove about 150 miles yesterday and could not get her to travel at 80mph without the boost guage reading 0 or just below, I am fairly sure I should be able to cruise without any turbo pressure negative or positive, maybe someone could confirm this? This seems to have resulted in her drinking fuel at a rate of knots!!! Today, set off to zoo with the crew (it's only 20 miles away) and just as I am getting towards the zoo the warning light comes on, then 10 seconds later the oil light comes on. I pull over, let her rest for a short while (i know should have let the oil all drain back out of engine) and checked oil. Was suprised to see her at the minimum oil level, she had an oil change on Friday last week and still had some oil, so topped it up and abandoned zoo idea to get home. Just before I departed though I noticed oil dripping out underneath, not a small amount, on the right hand side of the engine as you look at the engine. Glad to say I have got her home but was dripping oil for 30 mins after I got back. It seems to be under the oil filter but oil filter seems to be dry! I can't get under to have a proper look, but was just wondering, what else is in the general vicinity of the oil filter that could be allowing oil to escape? It only seems to do it when engine is running or for a while after I switch engine off! Oh, I have checked oil and it seems to be full, I could have over-filled it when I panicked earlier, I will drain some out before driving again.... I learn't a lesson today, be calm and wait before testing the oil level Link to comment Share on other sites More sharing options...
SimonB Posted July 17, 2005 Share Posted July 17, 2005 Oil leaks like that will only show up when the engine is running and the oil system is pressurised, so that's to be expected. If you've just changed the filter I would check it's done up tight enough, not cross threaded and has a good seal etc. Link to comment Share on other sites More sharing options...
TimH Posted July 17, 2005 Author Share Posted July 17, 2005 Just checked and there was oil on the filter, but it was done up tight enough, however there seemed to be more oil ABOVE the oil filter than actually on it...... are there any oil seals that may have gone which would be located above said oil filter? Link to comment Share on other sites More sharing options...
John_M Posted July 17, 2005 Share Posted July 17, 2005 Had similar leak which turned out to be the oil pressure switch. Link to comment Share on other sites More sharing options...
TimH Posted July 17, 2005 Author Share Posted July 17, 2005 Ok, just went out to just turn engine over and can see (not really from where) oil being PUMPED out of the system, looked by my left passenger side wheel and there is a black stream of oil, checked oil level and it is now half empty............ Anyone any advice, does this sound really bad? Edit, mechanic put in brand new millers 10w60 fully synth on Friday, the filter appears not to be leaking at all, it seems to be further over (under throttle body maybe bit further) Link to comment Share on other sites More sharing options...
absz Posted July 17, 2005 Share Posted July 17, 2005 if its started when you changed oil filter then just remove oil filter and check to make sure that the o-ring seal on the filter is still there. as sometimes the seal does drop out when fitting. Link to comment Share on other sites More sharing options...
TimH Posted July 17, 2005 Author Share Posted July 17, 2005 Defo not the filter, I think it may be an oil seal somewhere or a pipe, it really has pumped out half it's oil in about 2 mins.... Filter seems reltively dry but I could see oil being pumped from somewhere Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted July 17, 2005 Share Posted July 17, 2005 best get somebody to come over and check your car and dont drive it, may be a hose off or split and i wouldnt risk my engine goozing Link to comment Share on other sites More sharing options...
Scooter Posted July 17, 2005 Share Posted July 17, 2005 Had similar leak which turned out to be the oil pressure switch. I bet its this too.......good news is that its about £10 for the part and labour shouldn't be too bad £150 all in maybe? Link to comment Share on other sites More sharing options...
TimH Posted July 17, 2005 Author Share Posted July 17, 2005 I'm not driving her anywhere, she is staying put until I can diagnose the problem. The garage who did the oil change are going to have a look tomorrow, I so hope it's a nice easy one...... Someone mentioned a cracked block, but in all seriousness wouldn't have ALL the oil drained out by now if that was the case (not just when it was under pressure???). I love my Supra, but she has tested my patience today Link to comment Share on other sites More sharing options...
Dave222 Posted July 17, 2005 Share Posted July 17, 2005 Oil pressure switch is a good place to start, if you can get front up on axle stands and remove the passenger side wheel you should be able to see where its coming from. When it starts to leak from the switch it pisses out or at least mine did and that started after an oil change!! Good luck. Link to comment Share on other sites More sharing options...
TimH Posted July 17, 2005 Author Share Posted July 17, 2005 Oil pressure switch is a good place to start, if you can get front up on axle stands and remove the passenger side wheel you should be able to see where its coming from. When it starts to leak from the switch it pisses out or at least mine did and that started after an oil change!! Good luck. Cheers mate, you just made me feel a damn site better than i was Link to comment Share on other sites More sharing options...
TimH Posted July 21, 2005 Author Share Posted July 21, 2005 reason being the filter failed BIG time, Seal was shot on it... all fixed FOC Link to comment Share on other sites More sharing options...
Guest Usmann A Posted July 21, 2005 Share Posted July 21, 2005 mm, thats my avatar mate ...... Link to comment Share on other sites More sharing options...
TimH Posted July 21, 2005 Author Share Posted July 21, 2005 He he sorry matey, I have been using it on my other forums for a bit, I will pick a new one soon Link to comment Share on other sites More sharing options...
Guest Usmann A Posted July 21, 2005 Share Posted July 21, 2005 no its cool man, i was just messing ... Link to comment Share on other sites More sharing options...
