supna Posted January 27, 2003 Share Posted January 27, 2003 My passenger side window goes about 2-3mm higher than it should causing the passenger door not to close properly. Is there any easy way just to tweek the window down a bit. Thanks David Quote Link to comment Share on other sites More sharing options...
Supra Pilot Posted January 27, 2003 Share Posted January 27, 2003 Raise the roof or get an aerotop...... Quote Link to comment Share on other sites More sharing options...
matt Posted January 27, 2003 Share Posted January 27, 2003 You'll need to remove the door card and adjust the stops. They are situated on the top edge of the door, on the inner face of the double skinned section. The adjuster is a cup type thing ..... it will become clear once the door card is off Quote Link to comment Share on other sites More sharing options...
Steve W Posted January 28, 2003 Share Posted January 28, 2003 It can be a bit 'trial-and-error'-ish as, if you lower it a tad TOO much you get a bit of wind noise at high speed from the top edge of the window = I KNOW ! Quote Link to comment Share on other sites More sharing options...
