Crower Cams
Alex
Guest Martin F
Crower come reccomended by some of our American friends, particularly for their pistons.
Make of that what you will!
I've seen it on a few MkIV's, in magazines and at shows.  I think HKS do a cam cover with a cut-out in it precisely for that reason, and who can blame them with such sexy anodised vernier cam gears!
If you're worried about it, cut a window out and then glue in a piece of clear perspex, but I don't think it should be an issue.  AFAIK it's just there to protect the cambelt from knocks and scrapes, and stop it getting soaked in oil or anything.
Had a response from JUN on the price for the following...
1. JUN innner shim camshaft kit  JPY 178,000 which includes;
1x high lift 272deg camshafts (10.8mm lift) for intake,
1x matching exhaust cam,
Valve spring set,
Special titanium retainer set.
2. Valve lifter set (24pc)  JPY 39,000
3. Shims (24pc)   JPY 21,600
4. Valve guide set  JPY 38,400
5. Transfer charge by EMS  JPY 29,200
6. Domestic bank commission  JPY 4,500
Total prices  JPY 310,700
310,700.00 JPY = £1,641.10 GBP
So for all the head components to be replaced bar the valves themselves it will cost about 1700 of your poundlets :)
Not bad at all, just the head work replacement pistons and valves to go....:)
