spiderpigcity Posted September 28, 2011 Share Posted September 28, 2011 I know it sounds stupid but try jumping the battery with another car, my alarms plays up under anything below 13.2v and wont start, no fuel pump, same probs as you. Quote Link to comment Share on other sites More sharing options...
Guest Rsand85 Posted September 29, 2011 Share Posted September 29, 2011 yet again no joy all the plugs are fine mite start swapping relays one at a time i think worth trying the igniter atall? Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted September 29, 2011 Share Posted September 29, 2011 have you checked the crank sensor plug is ok? and the igniters do fail Quote Link to comment Share on other sites More sharing options...
Guest Rsand85 Posted September 29, 2011 Share Posted September 29, 2011 is there a crank sensor on na?thought it was all done from distributor/cams would the igniter failing cause this though? Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted September 29, 2011 Share Posted September 29, 2011 ok, wasnt sure i thought some had. anyway there is something not working that is not sending a signal back to the ecu to trigger the pumps and ignition. I have had seen a few ignitors fail. sorry i can't help you any more/ Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted September 29, 2011 Share Posted September 29, 2011 make sue the snap lock is fully snaped in on the orange plug in the footwell. and check you havent bent any of the pins if the grey plug was wrong thecar wouldnd crank atall Quote Link to comment Share on other sites More sharing options...
Guest Rsand85 Posted September 29, 2011 Share Posted September 29, 2011 i didnt have it unplugged but i did check it tonight to its snapped in good mate Quote Link to comment Share on other sites More sharing options...
Guest Rsand85 Posted October 3, 2011 Share Posted October 3, 2011 has anybody got anymore bright ideas about this one?? Quote Link to comment Share on other sites More sharing options...
