Any Audi experts around??
trinitom
Got an a4 (b8) a few months ago, and since i have it the airbag light it's always on and the buttons on the steering wheel don't work.
I did search for this problem over the net, and it seems the problem could be from the clockspring behind the wheel.
any experts around before i take the car to a dealer? :)
If you were nearer I have the latest Bosch KTS which would show the cause straight away. Some local VW / Audi / Skoda enthusiast may have a cut down VAGCOM you could try.
Chris how do you find the kts machine as i'm thinking of buying one (pc based) i have been on all the bosch diagnostic courses but every time we used the tablet based machine we had problems.
PS sorry for the hijack
clock spring sounds like a good bet. have you had it plugged in at all?
I don't know, and i didn't touch it.
I would like to know more possible causes before i start removing stuff!
I went to a friend mine that works for vw/skoda but they don't have the vagcom for B8 models, only B7.
don't know about the Bosch unit, but in Audi forums.com they do talk alot about the Ross-tech Vagcom.
http://www.ross-tech.com
Anybody with even Snap~On or Sykes Pickavant diagnostic software should be able to diagnose the fault, if there's no communication between the wheel and the clockspring, there will be a diagnostic trouble code. The light on the dashboard alone will have stored a DTC.
In order to turn the light off he would have had to read the DTC. If you can get the DTC and let me know, I can look it up on Autodata and give you possible causes. But no, Audi don't use blink codes, it needs to be plugged in buddy.
Shame!
I think i'll live it to the pro's, i may only remove the steering wheel to see if there's something lose inside.
But thanks anyway for the help. ;)
thanks peps.
IMHO modern Audis are trouble, I don't think I have come across one with a couple of years or more on it that hasn't got SOME sort of electric issue :( Some are a nightmare to fix.
They are a pain in the groin Chris. Fantastic until they break. Usually ABS, Airbags or general CAN system faults I've found.
P.S. I've not forgotten you Chris, just waitng for a cheque to clear.
I had a BMW 320 e90 before, but i always wanted an A4 avant tdi, i just hope this wasn't bad move.
The radio controls from the steering wheel are CANBUS the only thing in common with the airbag unit is the clock spring the multi-plug which connects under the steering wheel and the main ignition feed, so check ALL fuses thats all you can do. also has it the orignal steering wheel fitted or has someone upgraded to say a S-line
I believe it's the normal steering wheel, as there is no s-line on the wheel.
All the fuses have been looked, and they are all good.
