Guest Rsand85 Posted September 18, 2011 Share Posted September 18, 2011 im not getting any power coming into the coil on a 94 manual na tried a search but couldn't find much anybody able to shed some light on what to check next?cheers Quote Link to comment Share on other sites More sharing options...
absz Posted September 18, 2011 Share Posted September 18, 2011 you should have a 12v feed to the coil via ignition and a negative which is only triggered via the distributor,If the 12v postive feed is there then its more than likely a distributor problem. Quote Link to comment Share on other sites More sharing options...
Guest Rsand85 Posted September 18, 2011 Share Posted September 18, 2011 i was expecting it to be a distributor prob to but im not geting any power coming to the coil at all:( Quote Link to comment Share on other sites More sharing options...
absz Posted September 18, 2011 Share Posted September 18, 2011 How are you checking the power feed? ie multimeter if so connect one probe to the battery negative and use other probe on the coil pins to see if there is voltage,If you have no voltage then it can be a fuse/alarm or even a broken wire issue. Quote Link to comment Share on other sites More sharing options...
Guest Rsand85 Posted September 18, 2011 Share Posted September 18, 2011 yup that's exactly how i was checking all the fuses are good,its a clifford alarm with intellistart never given bother before looking like a broken wire car hasn't moved that's whats confusing me was working fine then next day nothing!! Quote Link to comment Share on other sites More sharing options...
absz Posted September 18, 2011 Share Posted September 18, 2011 You can apply 12volts to pin 1 of the coil to see if you gain a spark while cranking. Quote Link to comment Share on other sites More sharing options...
Guest Rsand85 Posted September 18, 2011 Share Posted September 18, 2011 true never thought of thet now:rolleyes:cheers will give that a go tomorrow see what happens Quote Link to comment Share on other sites More sharing options...
