Clutch Issues
Parry_10
Hi guys,
Have been putting up with this for ages now and ive had enough.
I have a w58 gearbox, 6 puck competition clutch running bpu
1. When pulling off the clutch is juddery which I guess could be normal for this type of clutch?
2. When I drop down gears say 5th-4th is fine, 4th-3rd is fine its when I try to drop down from any gear to 2nd i get a big judder and it feels like my gearbox is going to fall off!
3. the clutch pedal squeeks but then if I go and give the car some stick it stops squeeking? Then the next day it will squeek again until I give the car some stick again.
Also sometimes its harder to put into gear but then sometimes its easier- doesnt make a difference if the car is hot or cold. The only thing I can think of is maybe the pushrod needs adjusting, would this cause any of these problems?
Chris
I take it you did a NA-TT conversion? regarding judder did you put the second mount in the diff? might be worth a shot.
yeh thats right jamie, I did have that thought in my head because I didnt put the 2nd mount in but it seems strange it only does it when pulling off and when I drop it into 2nd. I would have thought just pulling off would not put enough strain on the diff mounts to cause a problem but maybe I am wrong
  • 1 month later...
