Dim Sum Posted September 17, 2011 Share Posted September 17, 2011 I've only recently joined in the turbo side of the supra over the one year of ownership. To be fair I'm addicted to the turbos:d but what are the maximum capabilities of the stock turbos? I have UK engine and turbos with full BPU, boost controller and etc. What are the next steps to increase performance without changing the turbos or there ain't a next step? Quote Link to comment Share on other sites More sharing options...
Ian W Posted September 17, 2011 Share Posted September 17, 2011 That's you I'm afraid, depending on your boost settings. Next step would be hybrids or going single. Quote Link to comment Share on other sites More sharing options...
Scott Posted September 17, 2011 Share Posted September 17, 2011 With UK turbos you can set the boost to 1.4 if you like. Personally I wouldn't go past 1.3 on UKs as I can't see there being any gain due to increased heat. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted September 17, 2011 Author Share Posted September 17, 2011 That's you I'm afraid, depending on your boost settings. Next step would be hybrids or going single. what about a remap? I aware it probably be better for fuel consumption but possible for a few gain in BPU? With UK turbos you can set the boost to 1.4 if you like. Personally I wouldn't go past 1.3 on UKs as I can't see there being any gain due to increased heat. I've heard you can adjust it to 1.4 but never have put that setting in the controller, i have set 1.3 bar on the Scrum button:d Otherwise i'm better off saving next year for bigger turbos. Quote Link to comment Share on other sites More sharing options...
Scott Posted September 17, 2011 Share Posted September 17, 2011 what about a remap? I aware it probably be better for fuel consumption but possible for a few gain in BPU? I've heard you can adjust it to 1.4 but never have put that setting in the controller, i have set 1.3 bar on the Scrum button:d Otherwise i'm better off saving next year for bigger turbos. You can set it at 1.3 no bother and change the scramble button to 1.4. On a short burst you should see a bit of a difference Remapping the car will gain you a bit of power and a bit more middle end grunt (the mines ECU shows this) but for the money involved I would only get a stand alone ECU if you planned on going single later on. Ahh, you got it working then What was the issue? Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted September 17, 2011 Author Share Posted September 17, 2011 You can set it at 1.3 no bother and change the scramble button to 1.4. On a short burst you should see a bit of a difference Remapping the car will gain you a bit of power and a bit more middle end grunt (the mines ECU shows this) but for the money involved I would only get a stand alone ECU if you planned on going single later on. Ahh, you got it working then What was the issue? I assume i have it working, but the gains on quite high still. for me to get 1.1 on third gear the gain is around 65 and on 1.2 bar of boost i've set it on 70 :/ I just didnt want to keep hassling you on Pm Quote Link to comment Share on other sites More sharing options...
Scott Posted September 17, 2011 Share Posted September 17, 2011 I assume i have it working, but the gains on quite high still. for me to get 1.1 on third gear the gain is around 65 and on 1.2 bar of boost i've set it on 70 :/ I just didnt want to keep hassling you on Pm I'm thinking that might be normal due to you having UK turbos. They are a little laggier so the gain probably needs to go higher. Don't worry about increasing the gain, as long as you don't overboost you will be fine Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted September 18, 2011 Author Share Posted September 18, 2011 I'm thinking that might be normal due to you having UK turbos. They are a little laggier so the gain probably needs to go higher. Don't worry about increasing the gain, as long as you don't overboost you will be fine Thanks for the advice. If the Stock turbos blow what a great reason to tell the other half, i need another turbo:d Quote Link to comment Share on other sites More sharing options...
Nic Posted September 20, 2011 Share Posted September 20, 2011 (edited) Old post HERE in answer to a similar question. The UK turbos are a little different as you don't need a restrictor ring but will need a boost controller to raise the boost pressure, but tuning steps and peak power will be similar. Edited September 20, 2011 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted September 20, 2011 Share Posted September 20, 2011 You could also look at going down the route of higher lift cams and mapping them in - that would see a bit of an increase but for the money it's probably not worth it by the time you buy cams, piggy back ECU (or standalone if you think you might go single in the future) and get it all fitted and mapped. Not sure what the BPU + crowd are running - probably around the 420-450 mark I would think. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted September 20, 2011 Share Posted September 20, 2011 The search button seems to be playing up again... Quote Link to comment Share on other sites More sharing options...
