rough price guide please
peter richards
best to order the x2 breather hoses that go between the cam covers as these almost certainly will be brittle and it makes things far easier if you can just cut off the old.
I would take off the green plug cover and have a look at the front most coil pack/front 2 plugs. You can then see the 'clips' that go brittle and with a screw driver you could remove one (you need to push in a part of it to unclip - the usual electrical clip thing) and see how bad it is. It's not like they will definitely fail/crumble its just they may be happy/ok in situ now but fall apart and then be useless if you remove and they do crumble. If you don't need the car 24/7 i'd get out there and have go at exposing removing the first coil pack.
