single turbo set up im thinking of doing!
jjs_82
Hi everyone,
I'm thing of going single turbo! Going for about 600bhp so the engine remains safe!!
Here's a list of things i'm going to buy for the car, so if anyone can advise or add to the set up please let me know!![GRIN][/GRIN]
Garage Whifbitz S366 66mm twin wastegate twin scroll single turbo kit
Fuel rail kit with 1000cc injectors
Fuel pressure regulator
Bosch 044 pump
BC cams 264 and Valve Spring & Retainer (these are the 2jz-ge cams from a is300 so i can have the VVTI)
Adjustable Cam pullys
Syvecs S6GP
Some of these things are kinda over and above what i need but i dont want to be running things on it's max i want to keep her safe!!
As i said before too if any of you guys have any advice or info on this i would be greatful
Cheers. Things i have
FMIC
Oil cooler
Exhaust
Clutch
Gauges boost water temp and oil pressure
Dump valve
Edited by jjs_82 (see edit history)
Are you aiming for 600bhp with some room to go for a larger turbo if you feel it too "inadequate"? :D
Also as John mentioned, is it 6spd or auto? This is very important...
If you want to aim for a genuine 600hp range you're going a bit overkill in som areas such as the injectors, FPR, etc.. The tock system is fine at those levels along with some simple drop-in injectors. Changing the cams will also be overkill at these levels if the engine is a VVTi.
Gauges wise, I disagree a bit with the above. AFR and boost are essential (good gauges with peak hold and ideally playback, though with the S6 and some logging this is not important). Oil temp & pressure is also a nice one, but the rest are really more worry gauges and only needed if you are planning track days.
Here's my list, might help you....
Single List Update
Already on the car:
Greddy 4 Row FMIC - £800
HKS SSQV2 Dump Valve - £200
AFR Gauge - £190
EGT Gauge - £100
Boost Gauge - £60
New Oil Pump - £140
New Water pump - £120
Front Crank Oil Seal - £40
Bought (required Items):
Turbo Kit (BL 4" down/mid pipe, BL manifold, AEM intake, lines etc), 900cc Bosch Injectors, FIC rail, GSC Stg1 Cams - £1900
Precision 6765 Billet Turbo - £700
ASI Radiator - £100
Bosch Fuel Pump - £115
Titan/ATI Crank pulley - £250
Aeromotive FPR - £100
Aeromotive Fittings - £30
Fuel Lines - £240
HKS Ti 4" Exhaust System - £600
ECU Sensors, Solenoid, Lambda & Switches - £280
Oil Sandwich Plate - £26
OEM Manifold Nuts - £20
OEM Manifold Studs - £10
OEM Timing Belt - £31
OEM Aux belt - £40
BC Stainless Springs & Retainers - £285
Bought (Recommended but Non-Required Items):
Power Steering Cooler Kit - £70
Vernier Cam Pulleys - £80
Billet Timing Tensioner Bracket - £150
Oil Cooler Kit - £115
ARP Head Studs - £100
OEM Gasket Kit - £240
OEM Crank Pulley Bolt - £8
OEM Thermostat - £40
OEM Sump Bolt - £5
OEM Sump Washer - £1
Oil Pressure/Temp Gauge - £150
Still to Buy (Required):
Valve Shims - £100
Solaris ECU - £1600
RPS Carbon/Carbon Clutch - £1800
Nice list Scott, very informative..
Just some questions..
About the cooling system, would a new OEM radiator not suffice for this power level?
The FPR is optional according to Homer?
I would ditch the stock FPR regardless, it doesn't take a lot to do it and an aeromotive gives you better control over the fuel. The stock fuel lines are more than enough for that sort of power though.
An OEM radiator is right as rain, the reason I went with aftermarket is that I got it for a good price and mine was on its last legs :)
BTW, remember that this is my list. The FPR isn't an option for me ;)
Ok, thanks... I realise that is your choice.. For the cost of the FPR I would throw it in the mix as well..
Highly doubt it, would need a double. That's the reason I'm going with the bosch, good for ITRO 700hp. I wouldn't fancy pushing it past 750 though.
Ok cool...
Its amazing how addictive this stuff is, I always had the intention of staying at BPU, that single turbo build is beginning to turn into a reality with every post on this forum.. :D
Ok cool...
If toyota would get the finger out.... yeah :D
I fancy manifold wrapping tomorrow.
Ok sorry every one i should have said what i have. {98 vvti tt6} Blitz Nurspec catback with 1st and 2nd De-cats. Greddy front mount inter cooler. Trust oil cooler. Fidanza lightened flywheel. Whifbitz braided fuel hose to remove pulsation damper. Blitz oil pressure gauge. HKS dump valve. Blitz SBC (Sequential boost controller). Apexi pillar mounted gauges (boost and temp Apexi turbo timer. Spec clutch kit. HKS twin power High performance ingintion system Type DLI.
One never said they were all needed matey just advise on what he could look into.
