can sticky injectors be repaired
mellonman
I had the same thing, And it turned out to be my plugs, even though i only had them in for about 2k miles. was'nt too happy. I dont know if this is true or not, But i was told you can damage the iridium sparkies by doing short trips, or turning you engine on and off for brief moments of time i.e moving the car 6 foot up the drive, which is what i did alot of.
See the end of the article, I use a low amperage current clamp to read the opening current, it easily spots most sticking injectors. Without this you will probably be guessing unless one sticks altogether, or is chronically bad.
i would say would you be able to have a look for me but your quiet far away, im going shakespeare race way on the 15 of october i could maybe come up to you on the friday for you to have a look or the saturday maybe,
it does seem very intermitant would you be able to pick it up as i would say it only does it once a month?
i have a aem fic would this help in fault finding the injector when it happens would the duty cycle be lower on that injector?
Edited by mellonman (see edit history)
Thanks for the replies chris,
looks like i will have to take them out then, if i did take them out would a flow test pick up the faulty injector? then i could sell the good one as a set of 4.
funny i wouldnt of said these have even done 10,000 miles, ever heard of the seimens deka 630cc failing
looks like i will try the plugs first then you never know might have a dodgy plug
