barneybrendan Posted September 13, 2011 Share Posted September 13, 2011 I want the rivets on show on my rear arches.Is there any specific ones to use which are best for this sort of thing . Link to comment Share on other sites More sharing options...
JamieP Posted September 13, 2011 Share Posted September 13, 2011 Orange beast had very small allen head nuts and bolts on the arches, looked cool. Link to comment Share on other sites More sharing options...
barneybrendan Posted September 13, 2011 Author Share Posted September 13, 2011 i was thinking of that but not sure if i will be able to get at the back of bolts inside the car Link to comment Share on other sites More sharing options...
Blackie Posted September 13, 2011 Share Posted September 13, 2011 i was thinking of that but not sure if i will be able to get at the back of bolts inside the car Can you not get selftapper allen head bolts? Link to comment Share on other sites More sharing options...
barneybrendan Posted September 13, 2011 Author Share Posted September 13, 2011 Can you not get selftapper allen head bolts? not sure they would hold good enough to be honest. would rivet nuts work or would that make the arches sit out proud too much Link to comment Share on other sites More sharing options...
Blackie Posted September 13, 2011 Share Posted September 13, 2011 not sure they would hold good enough to be honest. would rivet nuts work or would that make the arches sit out proud too much Not that i know alot about it but i think there could be a danger of bits of the kit lifting, At least with self tappers you can losen them off and flaten the panels down, With rivits it could lift then you will ahve to drill them out and have the same problem imo Link to comment Share on other sites More sharing options...
barneybrendan Posted September 13, 2011 Author Share Posted September 13, 2011 im going to take the interior panels off and check to see if i can get to the back of the cars bodywork to see if i can fit nuts and bolts as in Jamie's idea. Link to comment Share on other sites More sharing options...
David P Posted September 13, 2011 Share Posted September 13, 2011 I thought you were onto a winner with the rivnuts. Link to comment Share on other sites More sharing options...
barneybrendan Posted September 13, 2011 Author Share Posted September 13, 2011 I thought you were onto a winner with the rivnuts. just watched a video of them on youtube but they leave a collar around the outside like a washer.Im not going to dismis them as i was thinking of putting a small adhesive strip between the arch and the body. Link to comment Share on other sites More sharing options...
RobD Posted September 13, 2011 Share Posted September 13, 2011 Riveted nuts work ok for that, a mate just had his s13 wide arch kit put on with those and they haven't left gaps at all I'll try get a close up pic for you Link to comment Share on other sites More sharing options...
barneybrendan Posted September 14, 2011 Author Share Posted September 14, 2011 Riveted nuts work ok for that, a mate just had his s13 wide arch kit put on with those and they haven't left gaps at all I'll try get a close up pic for you cheers Link to comment Share on other sites More sharing options...
Noz Posted September 14, 2011 Share Posted September 14, 2011 Why not line them up with nuts first, then rivet after to make sure holes line up pukka? Link to comment Share on other sites More sharing options...
barneybrendan Posted September 14, 2011 Author Share Posted September 14, 2011 As ive said noz not sure i can get at the back to fit nuts yet. Link to comment Share on other sites More sharing options...
Noz Posted September 14, 2011 Share Posted September 14, 2011 hmmmmmmmmmmmmmmmmmmm thats a bummer, what about using over sized bolts, they might thread into the hole and not give the harsh effects of a self tapper but might just allow you to sit the archs to check? Link to comment Share on other sites More sharing options...
