redsupraman82 Posted September 12, 2011 Share Posted September 12, 2011 hey guys, well finally fitted everything after doing my N/A to TT swap but she wont start! she will crank but not fire! after looking under the car and checking fuel lines they were empty! so i guess i have a fuel pump problem. i can hear any whining when i turn the key, how can i check or resolve this?? by the way it was a N/A auto N/A (94) and have put in a 97 TT lump and a w58 with a manual ecu which was already connected to the engine when i got it, including a flywheel so im asuming it came from a manual set up! Please help i really want to start her today! Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted September 12, 2011 Share Posted September 12, 2011 I take it you mean you can't hear any whining when you try and start it? Have you check the simple things like fuses and connections? Maybe get a voltmeter to check you have power to the pump? Failing that it might be a blockage in one of the lines. Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 12, 2011 Author Share Posted September 12, 2011 checked for blockages all good! i just dont think any power is getting to it! is there any fuses i can check? Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 12, 2011 Author Share Posted September 12, 2011 just been having a good check however i did find that my fuse box has no wiring for EFI 2? as its a N/A auto fuse box..... could this be the problem? if so how do i fix it! Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 12, 2011 Author Share Posted September 12, 2011 KKKKEEEEERRRRROOOOONNNN!! keron can you help?any ideas?? Dammit im so close! Quote Link to comment Share on other sites More sharing options...
Odin Posted September 12, 2011 Share Posted September 12, 2011 (edited) mate i had the same problem recently - to check if it is the relay etc take out the efi 1 and bridge it with a paperclip to see if the car starts?also see if u have 12v to the coilpacks and pin 1a in the loom(black and orange wire) I was also told this problem could be fixed by splicing pin 24a(grey wire) into pin1a(black and orange) but this unfortunately didnt work for me - thats basically where i got to before i had to call Ryan at 2bar tuning to help me out so if i find out anything ill let you know Edited September 12, 2011 by Odin (see edit history) Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 12, 2011 Author Share Posted September 12, 2011 thanks dude i will try that Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 13, 2011 Author Share Posted September 13, 2011 any other ideas??? Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 13, 2011 Author Share Posted September 13, 2011 would i need to do the 12volt mod?? i have tried bridging in in the diog port but still nothing! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 13, 2011 Share Posted September 13, 2011 Just take power straight to the pump, under the cover ion the rear hatch area (under the spare wheel) Pull the connector plug off and take 12 volts direct to the pump terminals, be careful with polarity. Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 13, 2011 Author Share Posted September 13, 2011 cool i will try that, but which teminal is which on the plug i dont want to short anything out! Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 14, 2011 Author Share Posted September 14, 2011 would this be the same as doing the 12volt mod or would it mean running it straight from the battery? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 14, 2011 Share Posted September 14, 2011 I would check which of the terminals at the tank connector go to the pump, check the polarity, and take a feed direct for initial testing, then work back from there if the pump runs. You may have to take the tank unit out to check the connectors / polarity, I can't find a drawing. BE VERY CAREFUL OF SPARKS AND PETROL / PETROL FUMES!!!!!! Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 14, 2011 Author Share Posted September 14, 2011 thanks chris i will give this a go! Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 19, 2011 Author Share Posted September 19, 2011 pk a quick update..... i have checked the pump and that works im even getting power to the connector to the pump. however im getting no voltage from the fuel pump ecu? is there any way i can bypass it?? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 19, 2011 Share Posted September 19, 2011 You can bypass the ECU using a paperclip and shorting ports B+ and Fp in the diagnostics connector under the bonnet. That will put the pump to 12v output but beware, that clip get very hot! Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 19, 2011 Author Share Posted September 19, 2011 i have already tried that and no go. however i dont think im getting voltage to the right ports on the plug for the fuel pump Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 19, 2011 Author Share Posted September 19, 2011 would anyone be willing to come and have a look at this problem? its driving me nuts now! i think i have got it as far as i can. im in rickmansworth jun 17 off the m25. would be much appriciated! Quote Link to comment Share on other sites More sharing options...
David P Posted September 19, 2011 Share Posted September 19, 2011 I had similar problems after swapping the fuel pump in my N/A for one from a UK TT, the cure was to use a fuel pump ecu from a TT. Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 19, 2011 Author Share Posted September 19, 2011 i see where your coming from but i have no power even going to the N/A FP ECU i think its something to do with this EFI 2 business. Thanks for the input though david, so if anyone has a TT FP ECU please can i borrow it?? Quote Link to comment Share on other sites More sharing options...
David P Posted September 19, 2011 Share Posted September 19, 2011 Is there any chance there could be a fault between T.T. and N/A looms? Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 19, 2011 Author Share Posted September 19, 2011 it could be but i have done the fuse box mod for the wiring, electrics are really not my thing!! Quote Link to comment Share on other sites More sharing options...
David P Posted September 20, 2011 Share Posted September 20, 2011 Looks like a good place to look. Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted September 21, 2011 Author Share Posted September 21, 2011 i have checked and re checked the wiring i have done and its correct arfter lots of research so i know thats right i wouldnt know where to look after that! whos the best person to take her to, i will even get it traliered if i have to! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 21, 2011 Share Posted September 21, 2011 If I can't get it running I won't charge you... Is it a VVTi? Quote Link to comment Share on other sites More sharing options...
