kieren1234 Posted September 11, 2011 Share Posted September 11, 2011 Can someone post a picture or diagram of te way the timing belt goes onto the pulleys please. I have just changes the crank pulley and all the ways I have tried it's been seriously slack. Thank. Quote Link to comment Share on other sites More sharing options...
Scott Posted September 11, 2011 Share Posted September 11, 2011 Timing belt on the pulleys? Do you mean the aux belt rather than the timing belt? Have you fitted the aux belt tensioner? Quote Link to comment Share on other sites More sharing options...
johnny g Posted September 11, 2011 Share Posted September 11, 2011 Change your thread title to something meaningful. Click Edit then go Advanced. Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted September 11, 2011 Author Share Posted September 11, 2011 Yes aux belt I mean and tensionwr? Is that the free moving pullet that doesn't have guiding teeth on? Quote Link to comment Share on other sites More sharing options...
Scott Posted September 11, 2011 Share Posted September 11, 2011 It's a bit silly to take on a task when you have no idea what you are doing is it not? I recommend that you at least take pictures of things before you start ripping them off in future. Here is a picture of how the belts are setup. The tensioner is below the cams, right at the centre of the engine. It has a swing arm and a pulley wheel on it that rotates with tension. http://www.toyodiy.com/parts/diag_Za1od.png Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted September 11, 2011 Author Share Posted September 11, 2011 Thanks Scott. I did know what I was doing and j couldn't take a picture because my belt span off when the crank pulley outer part snapped off. I got the crank pulley changed and new one on in 45 minutes . Just needed to know about the belt and sorted it in the end. Thanks a lot mate. Quote Link to comment Share on other sites More sharing options...
