Wheel hop
Neil-NA
Usually getting rid of compliance in the rear suspension and drive train will cure it. Obviously damper settings need optimizing, too.
So new arms, diff bushes etc. What about the damper settings, i am currently on KYB with 4 stage settings and run them on the softest setting but i will be going back to stock rears with springs.
Just out of curiosity can you do anything with the KYB's like you do with the bilsteins Chris?
Could also be well off here but will a full set of titan solid diff / subframe mounts help.
What about tyre pressure? when i was at pod i have a feeling the pressure in the rears was around 40psi :blink: until i lowerd it to around 28 (however this happens with my normal tyres at 32psi)
  • 4 weeks later...
