Supercharger setup
barneybrendan
I have no love for the supercharger build now and its all but there,just the issue with the charger to sort out.this is either alignment or something to do with the tensioner.
engine and loom and custom double crank pulley with emu harness solderd in £700
celica st205 throttle cable £40
stainless tubular manifold £200
power enterprise cone filter £50
full 3" stainless decated exhaust £200
sard fpr £60
water injection system pump lines and tank. £150
lc1 innovate wideband £150
supercharger and all bracketry plus 3 pulleys and spare snout £600
magnusun bypass valve £100
all custom parts for the oil filter relocation.£150
greddy emu mapped for the larger pulley at 310hp £300
fmic and all the pipe work £300
550 injectors and uk resistor pack. £400
w58 5 speed gearbox. £600
eaton padle clutch kit,only done one dyno session since fitted. £250
Genuine trd quick shift. £200
auto rad and twin electric fans with switch relays and sensor.£160
both set ups either blow through the na throttle body , and the new set up with the v8 throttlebody before the charger. £180
THATS £4790
WOULD LIKE £4500 FOR EVERYTHING.
MAY SPLIT IF ENOUGH INTEREST.
