skippyboyo1 Posted September 7, 2011 Share Posted September 7, 2011 Hi guys as usual im in need of some help. Im talking to a company at the moment about some 18inch rota wheels. Now the package ive asked for is 8.5 fronts with an ET35 and 9.5 rears again with an off set of ET35. They have come back to me and said from stock they can supply me with exactly what ive asked for however the front wheels will be ET30. so my first question is what difference,visual or performance will the ET30 insted of my requested ET35 give?? ive not a clue when it comes to offsets. and then my second question,i always run avon zz3s (i do fast road stuff and lots of trackdays) and ive never had a problem with these tyres,however they have offered me the following....... 235/40R18 Falken FK452 front, 275/35R18 Falken FK452 rear........i just want to know what your thoughts are on these tyres and actual tyre sizes. Many thanks in advance!!!!!! Quote Link to comment Share on other sites More sharing options...
JamieP Posted September 7, 2011 Share Posted September 7, 2011 (edited) 8.5" et30 will be fine as long as the car is not slammed, i had rota 9" et30 on the front of the V8 supra and they cleared just fine. Falkens are not bad, best of the budget tyres id say. Edited September 7, 2011 by JamieP (see edit history) Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted September 7, 2011 Share Posted September 7, 2011 The difference between ET +35 and +30 is that the outside lip of the rim will be moved out 5mm closer to the wheel arch. Depending on the ride height of your car and the size of tyre you fit this may or may not be a problem. It also actually means that the inner lip is moved 5mm further away from the coilover but there really is no other issue regarding suspension characteristics when comparing these two offsets. Can't comment on the tyre options I'm afraid as I've used neither. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted September 7, 2011 Author Share Posted September 7, 2011 8.5" et30 will be fine as long as the car is not slammed, i had rota 9" et30 on the front of the V8 supra and they cleared just fine. Falkens are not, best of the budget tyres id say. so visualy then the offset wont be different then? the cars going low but ive had the arches rolled just to be safe jamie Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted September 7, 2011 Author Share Posted September 7, 2011 The difference between ET +35 and +30 is that the outside lip of the rim will be moved out 5mm closer to the wheel arch. Depending on the ride height of your car and the size of tyre you fit this may or may not be a problem. It also actually means that the inner lip is moved 5mm further away from the coilover but there really is no other issue regarding suspension characteristics when comparing these two offsets. Can't comment on the tyre options I'm afraid as I've used neither. ahhhh i see thanks buddy thats wicked that! Quote Link to comment Share on other sites More sharing options...
JamieP Posted September 7, 2011 Share Posted September 7, 2011 so visualy then the offset wont be different then? the cars going low but ive had the arches rolled just to be safe jamie As said above they will stick out 5mm further, as you have arches rolled they will be fine, mine was not rolled and i had a wider wheel on the V8. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted September 7, 2011 Author Share Posted September 7, 2011 As said above they will stick out 5mm further, as you have arches rolled they will be fine, mine was not rolled and i had a wider wheel on the V8. thanks jame sound that,ill get the bank account turned upside down in the morning! Quote Link to comment Share on other sites More sharing options...
imi Posted September 7, 2011 Share Posted September 7, 2011 If each wheel sits 5mm out then wouldn't the width of the front axle be extended by 10mm. Would that cause the car to understeer a bit more? Quote Link to comment Share on other sites More sharing options...
JamieP Posted September 7, 2011 Share Posted September 7, 2011 If each wheel sits 5mm out then wouldn't the width of the front axle be extended by 10mm. Would that cause the car to understeer a bit more? I doubt it, my front track is 108mm wider than stock (rear 130mm wider track) and it drives just as well as any other supra ive been in. Quote Link to comment Share on other sites More sharing options...
-Welsh-Stealth- Posted September 7, 2011 Share Posted September 7, 2011 ET30 8.5j front ET35 9.5j rear just so you can see how the front sit flush on the ET30 and the spokes come out further on the ET35 rota's i think it looks mean falken 452's ain't bad either Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted September 7, 2011 Author Share Posted September 7, 2011 ET30 8.5j front ET35 9.5j rear just so you can see how the front sit flush on the ET30 and the spokes come out further on the ET35 rota's i think it looks mean falken 452's ain't bad either thanks for that mate! i can see exactly what you mean! i like! Quote Link to comment Share on other sites More sharing options...
scotty71 Posted September 7, 2011 Share Posted September 7, 2011 (edited) I would over the Falkens go for Federal RSR 595's I can get them near cost http://image.ohozaa.com/ib/595rsr.jpg Edited September 7, 2011 by scotty71 (see edit history) Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 7, 2011 Share Posted September 7, 2011 Yer I hear good things about Falken tyres.~ Good thing with ET30 front you have a nice clearance for BIG brakes Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted September 7, 2011 Author Share Posted September 7, 2011 Yer I hear good things about Falken tyres.~ Good thing with ET30 front you have a nice clearance for BIG brakes ive seen alot of people changing the front brakes but out of all the trackdays ive ever done inc cadwell ive never felt the need to upgrade them to be honest.never been out braked ny anything or had brake fade Quote Link to comment Share on other sites More sharing options...
Scott Posted September 7, 2011 Share Posted September 7, 2011 I would over the Falkens go for Federal RSR 595's I can get them near cost http://image.ohozaa.com/ib/595rsr.jpg Are federals not ditchfinders? I thought they were disliked in the performance community. Quote Link to comment Share on other sites More sharing options...
scotty71 Posted September 7, 2011 Share Posted September 7, 2011 (edited) Are federals not ditchfinders? I thought they were disliked in the performance community. youre not thinking of Fullrun are you Scotty These RSR's are good value over R888's etc and are fully road legal like the 888's The Federal FZ-201's are a non road legal track day tyre and are a great price. Most forum's I have seen think they are good value over 888's The Federal FZ-201 (not road legal) http://89.206.185.119/images/product/product/fed_f2-2d1.jpg Edited September 7, 2011 by scotty71 (see edit history) Quote Link to comment Share on other sites More sharing options...
scotty71 Posted September 7, 2011 Share Posted September 7, 2011 (edited) Just to add scott camskill for a 255/40/17 are Toyo R888 - 183.00 Federal RSR 595 - 138.00 with me working for a tyre distributor I can sometimes get a good deal Edited September 7, 2011 by scotty71 (see edit history) Quote Link to comment Share on other sites More sharing options...
