Guest Tisi Posted September 7, 2011 Share Posted September 7, 2011 the enginee isn´t hot bot the water gauge is on top.. thermostat doesn´t work?? defect? where is it? how to change? thx community which steps to check it? Quote Link to comment Share on other sites More sharing options...
Scott Posted September 7, 2011 Share Posted September 7, 2011 Is it at the maximum when the engine is turned on? Ie, does it go to the top as soon as you turn the ignition on? The sensor is at the top water elbow so you will be able to feel the temperature with your hand. I'm not sure which way the guage goes when the sensor is faulty, seems a strange error. Quote Link to comment Share on other sites More sharing options...
Thorin Posted September 7, 2011 Share Posted September 7, 2011 Do you have coolant in the radiator? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 7, 2011 Share Posted September 7, 2011 How do you know the engine isnt too hot? Quote Link to comment Share on other sites More sharing options...
