scoooby slayer Posted September 6, 2011 Share Posted September 6, 2011 has anybody any experience with these at 8000 rpm ? http://wzeu.search-results.com/r?t=p&d=apn&s=zuk&c=a&app=aoth&l=dis&o=15634&sv=0a652926&ip=519dc465&id=A1FFB8F68BD96F50F5AF57E923875706&q=brian+crower+2jz+gte+valve+spring+max+rpm&p=1&qs=121&ac=524&g=5011dgVybkK3iI&cu.wz=0&en=gs&io=0&ep=&eo=&b=a001&bc=&br=&tp=d&ec=1&pt=Engine%20Parts%2F%20Cooling%20-%20Brian%20Crower%20Valve%20Spring%20Kit%20with%20Titanium%20...&ex=&url=&u=http%3A%2F%2Fwww.suprastore.com%2Fbrcrvakitwit.html they are claimed good for 8000rpm and have been tested to 9000rpm ? Quote Link to comment Share on other sites More sharing options...
Scott Posted September 6, 2011 Share Posted September 6, 2011 Just fitted these to my car. Not looking to go for 8k RPM though. I think you would be better with double valve springs given the power you are running. I assume you have some fairly wild cams? Better with the doublers Quote Link to comment Share on other sites More sharing options...
Bailey. Posted September 6, 2011 Share Posted September 6, 2011 As above, these are fitted to mine but i never intended going above 7.5k rpm, your build is going to be upwards of that so i would sat duals are the way forward.... Quote Link to comment Share on other sites More sharing options...
scoooby slayer Posted September 6, 2011 Author Share Posted September 6, 2011 Just fitted these to my car. Not looking to go for 8k RPM though. I think you would be better with double valve springs given the power you are running. I assume you have some fairly wild cams? Better with the doublers As above, these are fitted to mine but i never intended going above 7.5k rpm, your build is going to be upwards of that so i would sat duals are the way forward.... they are whats fitted in my new head thats on the shelf, they will be changed i think but was just curious what results people have had ? my current engine is on hks 272s not sure if il reuse them or not yet they are basically brand new ! they are making big claims about there springs i just wanted to see if there true ? Quote Link to comment Share on other sites More sharing options...
Ricky49 Posted September 6, 2011 Share Posted September 6, 2011 Jamesy and myself have them but we only rev to 7200 with them in. Migth be worth a pm to Lee. Quote Link to comment Share on other sites More sharing options...
scoooby slayer Posted September 6, 2011 Author Share Posted September 6, 2011 Jamesy and myself have them but we only rev to 7200 with them in. Migth be worth a pm to Lee. i think lee will change them when the time comes from what hes said, arent the stock springs good for 7200rpm anyways ? Quote Link to comment Share on other sites More sharing options...
Ricky49 Posted September 6, 2011 Share Posted September 6, 2011 Im changing mine to double spring with the next round of mods which Lee has advised with a set of his 280's and upping the rev limit into the 8's. Quote Link to comment Share on other sites More sharing options...
JamieP Posted September 6, 2011 Share Posted September 6, 2011 I would go dual, when mine had single supertech and 269 cams i suffered with valve bounce, power dropped off after 7000rpm. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 7, 2011 Share Posted September 7, 2011 You must remember that on a turbo or super charged engine not only have the springs to close the valves properly at whatever the engine revs to, but also to resist the boost pressure on the backs of the valve trying to stop them closing. If you have a seat area of say 1.5 square inches and a boost pressure of 30 PSI, that takes 45 pounds off the spring rate. You should also never OVER spring a valve as it reduces valve train life, creates heat and friction, and saps power. I ALWAYS say use the springs the CAM maker recommends, only mix and match if you know EXACTLY what you are doing. I also only use Japanese or German made springs, had a few bad experiences with American stuff. Quote Link to comment Share on other sites More sharing options...
