95supra Posted September 6, 2011 Share Posted September 6, 2011 I have a 1995 SZ with 2JZ-GTE V160 6-speed swap. Stock rear end and differential. I am wondering if a 1996.7+ facelift non-turbo SZ-R with the 6-speed transmission has the same differential 3.26 gearing differential as the RZ Supra's? My friend has the SZ-R which he just got. He's going to be using it as a show car. I talked about it and would be willing to trade differentials. So my questions are. Assuming the 6-speed SZ-R has the same 3.26 gearing differential, can I just bolt that onto my car? and bolt my 5-speed N/A diff on his SZ-R? Quote Link to comment Share on other sites More sharing options...
Nic Posted September 6, 2011 Share Posted September 6, 2011 Are both cars Japanese Supras? The gearing on the 6spd 2JZ-GE is 3.769. Below image taken from the Toyota EPC. http://img15.imageshack.us/img15/8526/picture1xxz.jpg What year is your mates TT? If it's a pre-facelift (93-96.7) 6spd 2JZ-GTE it will have the larger B diff fitted, different to your 6spd 2JZ-GE which will have the smaller A diff fitted. If it's a 96.7-02 facelift 6spd 2JZ-GTE it will have the small A diff, the same as yours. See HERE for pics of the different diffs. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted September 6, 2011 Share Posted September 6, 2011 SZ-R 6 speed has the same differential as the TT auto, 3.769. Small casing. They should still swap though. But I'm unsure if the prop needs modifying. Quote Link to comment Share on other sites More sharing options...
95supra Posted September 6, 2011 Author Share Posted September 6, 2011 both are j-spec yes. my 1995 sz has the 2jz-gte v160 6-speed swap. it has the original na 5-speed differential my mate has 1996.7 sz-r and wanted to steal his diff! Quote Link to comment Share on other sites More sharing options...
95supra Posted September 6, 2011 Author Share Posted September 6, 2011 by the way the reason I want a new differential is because my ODO is reading the mileage twice as quick. Also my speedo is very wrong, I can be doing like 80-100km and it will show 60km. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted September 6, 2011 Share Posted September 6, 2011 I think you're trying to fix the speedo/odo issues the wrong way. I'm not sure that the diff could throw the speedo/odo out like that but even if it could, something would need to be very wrong with the diff to make the speedo read double what it should. The speedo and the odo are fed from the same sensor. The sensor measures the number of hub revolutions. If one instrument is reading too many hub revolutions (i.e. odo counts up twice as fast as it should) and another instrument is reading too few revs (speedo is reading much lower than true speed), it would seem that there are problems with your wiring loom. Quote Link to comment Share on other sites More sharing options...
95supra Posted September 6, 2011 Author Share Posted September 6, 2011 problem with wiring room? with my harness? I know for a fact that it is reading twice as much. From my house to work its 20km in my old Supra, now it shows about 40km on ODO. Also the speedo reads lower than real life speed like I've specified. If there is a problem with my wiring loom I guess I'll need to take it to a professional. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted September 6, 2011 Share Posted September 6, 2011 Has your car always had these speedo and odo problems since you had the TT conversion done? Quote Link to comment Share on other sites More sharing options...
mark newman Posted September 6, 2011 Share Posted September 6, 2011 My speedo was reading way out about 20 mph wrong. when I had my 6 speed conversion done, it still had the tt auto diff in. But when I changed my diff to the large 6 speed . it was spot on. Quote Link to comment Share on other sites More sharing options...
95supra Posted September 6, 2011 Author Share Posted September 6, 2011 (edited) Has your car always had these speedo and odo problems since you had the TT conversion done? I am the third owner of the car. 1st owner did the swap, 2nd owner didn't know anything about cars, now I am left with practically no information. All I know is what I'm able to find out myself. The car has a very short first gear. Edited September 6, 2011 by 95supra (see edit history) Quote Link to comment Share on other sites More sharing options...
