heckler Posted September 5, 2011 Share Posted September 5, 2011 Pretty much the title really, it will just not behave, AEM WB has died, went on rolling road to confirm this, then kept popping a boost hose, the AFR keep changing by 1 AFR point from run to run, PAS pump is leaking - just driving me nuts. So tempted to put a match to it or sell it - oh and this is after 2 engine rebuilds. My 16 year old, £500 Ibiza has been more reliable. Not happy Quote Link to comment Share on other sites More sharing options...
johnny g Posted September 5, 2011 Share Posted September 5, 2011 Man that's not good. Chin up though, it'll get sorted! Quote Link to comment Share on other sites More sharing options...
tony tt Posted September 5, 2011 Share Posted September 5, 2011 I feel you're pain Simon but don't sell bud you're cars lovely it just needs some tlc dude. Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 5, 2011 Share Posted September 5, 2011 Sorry to hear this but why have you had 2 engine rebuilds ? Quote Link to comment Share on other sites More sharing options...
Scott Posted September 5, 2011 Share Posted September 5, 2011 Sorry to hear this but why have you had 2 engine rebuilds ? The first one failed him not so long ago. Chin up mate, just having a bad run of things with her at the mo Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted September 5, 2011 Share Posted September 5, 2011 A nice Syvecs will make your car feel better. By chance there is a group buy. Would you look at that Stay with it. You'll regain the love!! Quote Link to comment Share on other sites More sharing options...
heckler Posted September 5, 2011 Author Share Posted September 5, 2011 A nice Syvecs will make your car feel better. By chance there is a group buy. Would you look at that Stay with it. You'll regain the love!! It's not the ecu at fault Quote Link to comment Share on other sites More sharing options...
JamieP Posted September 5, 2011 Share Posted September 5, 2011 With regards to the boost pipes popping off what BOV do you have? Quote Link to comment Share on other sites More sharing options...
staples230uk Posted September 5, 2011 Share Posted September 5, 2011 Dude not good! Hope it all gets sorted for this weekend! Quote Link to comment Share on other sites More sharing options...
HadeS Posted September 5, 2011 Share Posted September 5, 2011 I had this same with my Sup, she drows me mad. I will get me revenge, I'm preparing her for something EXTRA ;D ... Drift season ;] She will blow up or enjoy. Quote Link to comment Share on other sites More sharing options...
heckler Posted September 5, 2011 Author Share Posted September 5, 2011 With regards to the boost pipes popping off what BOV do you have? Greddy type "s" - tbh, pipe poping off are probably due to the PAS pump leaking... fluid everywhere. Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 5, 2011 Share Posted September 5, 2011 Si, sometimes you get a stack up of things that really get you down, and it can be silly small stuff I've been there a few times, especially after you've just sorted a major problem. Where's the PAS pump leaking from? I just had a leak fixed at the steering box side of things, turned out a banjo pipe had finally corroded through to a pinhole. If it's getting over boost pipes though it must be higher up. It's an easy swap and if it's the bearings, CW will refurb the unit for you. As for the wideband, the sensors do have a limited life - how many miles have you done on it? A new Bosch 5.1 sensor is about £60 off ebay. Check it with a multimeter, I'm sure you know how to use one of those Quote Link to comment Share on other sites More sharing options...
heckler Posted September 5, 2011 Author Share Posted September 5, 2011 I can fix all this bar the AFR readings... as I (we) not sure whats causing it. Its a brand new Bosch 044 pump, fuel pressure is good etc.. So going to go down the line of putting in a new power supply/relay for the pump this week maybe.. Quote Link to comment Share on other sites More sharing options...
heckler Posted September 5, 2011 Author Share Posted September 5, 2011 Si, sometimes you get a stack up of things that really get you down, and it can be silly small stuff I've been there a few times, especially after you've just sorted a major problem. Where's the PAS pump leaking from? I just had a leak fixed at the steering box side of things, turned out a banjo pipe had finally corroded through to a pinhole. If it's getting over boost pipes though it must be higher up. It's an easy swap and if it's the bearings, CW will refurb the unit for you. As for the wideband, the sensors do have a limited life - how many miles have you done on it? A new Bosch 5.1 sensor is about £60 off ebay. Check it with a multimeter, I'm sure you know how to use one of those I know where your coming from I have a spare PAS pump sat in my shed, so that will be going in this week. The WB sensor is about 8 month old and done 2-3k. Not too fusses about the WB at the momment, just the variation in AFR when its was as SRR today.. Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 5, 2011 Share Posted September 5, 2011 If you're measuring the AFRs with a broken sensor then I wouldn't be surprised that the reading varies. If it's varying on SRR's sensor then you'll need to do more investigation as to what the pattern is - how much variation, what makes it change, that sort of thing. Datalog everything if you've got the ability, then you can see if injector duty changes, and if so, perhaps see what's causing it. Might just be a hole in your exhaust system mucking up the readings! Quote Link to comment Share on other sites More sharing options...
heckler Posted September 5, 2011 Author Share Posted September 5, 2011 If you're measuring the AFRs with a broken sensor then I wouldn't be surprised that the reading varies. If it's varying on SRR's sensor then you'll need to do more investigation as to what the pattern is - how much variation, what makes it change, that sort of thing. Datalog everything if you've got the ability, then you can see if injector duty changes, and if so, perhaps see what's causing it. Might just be a hole in your exhaust system mucking up the readings! yeah, been there with Matt from AFR - was planning to up the boost... well, never got that far! Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 5, 2011 Share Posted September 5, 2011 Si you know its a love hate thing... When its fixed and you drive it again you know you want be able to let it go! The exact same thing happened to me in February.. And kind of now.. Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted September 5, 2011 Share Posted September 5, 2011 It's not the ecu at fault I know. Just a shameless plug Quote Link to comment Share on other sites More sharing options...
Havard Posted September 5, 2011 Share Posted September 5, 2011 Sorry to hear this Si. This is why I never mod my Supes. H. Quote Link to comment Share on other sites More sharing options...
heckler Posted September 5, 2011 Author Share Posted September 5, 2011 Sorry to hear this Si. This is why I never mod my Supes. H. Yeah, once this one goes, I'll never mod another car to this extent.. Quote Link to comment Share on other sites More sharing options...
Havard Posted September 5, 2011 Share Posted September 5, 2011 Yeah, once this one goes, I'll never mod another car to this extent.. I would love to have the money to do it as I bet the performance is such a rush. I just know what happens in my head when things go wrong as my first reaction is to smash something up or or set fire to it. Or sometimes both..!! H. Quote Link to comment Share on other sites More sharing options...
scotty71 Posted September 5, 2011 Share Posted September 5, 2011 Pretty much the title really, it will just not behave, AEM WB has died, went on rolling road to confirm this, then kept popping a boost hose, the AFR keep changing by 1 AFR point from run to run, PAS pump is leaking - just driving me nuts. So tempted to put a match to it or sell it - oh and this is after 2 engine rebuilds. My 16 year old, £500 Ibiza has been more reliable. Not happy not good but.............. you have killer dash lights d00d let it know who's boss Quote Link to comment Share on other sites More sharing options...
heckler Posted September 5, 2011 Author Share Posted September 5, 2011 not good but.............. you have killer dash lights d00d let it know who's boss I only have fixed colour in mine - amber Quote Link to comment Share on other sites More sharing options...
secondjump Posted September 5, 2011 Share Posted September 5, 2011 Sorry to hear of your woes, Si. And there was me cursing because my radiator went the other month, after 6 yrs of single-ship and only use to spending on fluids and tires. Quote Link to comment Share on other sites More sharing options...
heckler Posted September 5, 2011 Author Share Posted September 5, 2011 Sorry to hear of your woes, Si. And there was me cursing because my radiator went the other month, after 6 yrs of single-ship and only use to spending on fluids and tires. well, now I've had a sit down and a think, it just means i can get a few things sorted, get engine loom changed over, pipes beaded, change the PAS pump etc... But I'll still be going to JAE with the car Quote Link to comment Share on other sites More sharing options...
