engine blowby flow meter
absz
Bit of a difficult one to measure, as in order to do so you need to disconnect and block off all the PCV system, i actually measured mine with and without the std PCV connected, and with an external catch tank, by using a low reading pressure gauge connected to the dip stick aperture, but could get no pressure reading, but nor did i get any vacuum.
Why do you think you need to test this?
You can purchase them from usa sites but require one local,The engine i require it for has the intake manifold incorporated into the rockercover housing with gaskets seperating the intake ports. its these gaskets that are leaking casing forced induction pressures entering the crankcase. but i need to do a detailed report of the repairs/findings to prove the repair once done. As a seperate company has recommended a full engine rebuild at a cost of approx £15k+ due to excessive blow-by.
