Guest seecarr11 Posted September 5, 2011 Share Posted September 5, 2011 hello I just finished a 1Jz-gte vvt-i swap into my IS200. recently i got a great deal on a supra brake kit (front calipers 4 pot uk spec). I'm gonna install those before the end of this month. So i thought i join up and say "hi" seeing as I'm slowing turn into a Frankenstein supra of sorts , so far i've got a mine's ecu, 3" stainless mandrel bend HKS exhaust and a Torsen LSD, TRD coilovers for the suspension. next i'll be looking for a boost controller to turn it up to a mild 1 bar of boost btw i've been searching the forum and i haven't seen any diy threads on brake pad changes for the UK spec brakes. (i found lots for the JDM brakes though) can anybody point me to a thread with that? thanks Quote Link to comment Share on other sites More sharing options...
dude Posted September 5, 2011 Share Posted September 5, 2011 Welcome, that will be a nice car, i do like an IS200. If you mean what pads should you fit then look no further than Chris Wilson on here, you want his fast road pads. Quote Link to comment Share on other sites More sharing options...
Guest seecarr11 Posted September 5, 2011 Share Posted September 5, 2011 thanks for the heads up. I already got some new oem toyota pad to go with the calipers. i was looking for a diy for the brake pad replacement here are some pics of the swap (before with the TTE supercharger and after)and my new powdercoated calipers, before and after. Quote Link to comment Share on other sites More sharing options...
