Guest tony1979 Posted September 4, 2011 Share Posted September 4, 2011 This is a stupid one i know but, ive disconnected the small fog light switch on the dash and i cant remember how to reconnect it, ive got a red and a blue cable and the symbols on the rear of the switch are, (+) , 12v and i think earth, but only 2 cables were on there, i feel so stupid now:( Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted September 4, 2011 Share Posted September 4, 2011 you only need power and earth buddy,are you saying there are 3 connections on the back? are you talking about a none standard rear fog light switch that has been fitted after production? if so it wont matter which way around you connect then the results will be the same. Quote Link to comment Share on other sites More sharing options...
Guest tony1979 Posted September 4, 2011 Share Posted September 4, 2011 Top man thanks for that, my luck and electrics dont mix. Quote Link to comment Share on other sites More sharing options...
Iky Posted September 4, 2011 Share Posted September 4, 2011 you only need power and earth buddy,are you saying there are 3 connections on the back? are you talking about a none standard rear fog light switch that has been fitted after production? if so it wont matter which way around you connect then the results will be the same. Unless the switch has a little LED light on on it like mine. If so just swap them round if it doesn't work. Quote Link to comment Share on other sites More sharing options...
mawby Posted September 5, 2011 Share Posted September 5, 2011 Please use more meaningful thread titles in the future. Quote Link to comment Share on other sites More sharing options...
