Squelley noise
Monster supra
Hi guys
I have just replaced head gasket
Got car back together & it starts ok
But
When i put foot on accelerator all power drops , car almost stalls & i loud squelley noise like air being released from balloon while stretching the neck of it !
Sounds like its from the trottle body area
Any ideas , been trying for two days now & not got much hair left.
have you rechecked all the vac lines? closing one of them can make the power drop when you accelerate (think its the one going to the fpr). i'd go all over the inlet side following all vac lines till you find one you havent put on in the right place or has a split.
if that fails you could post up a vid of whats happening to see if you can jog peoples memory if they have had a similar thing happen before
I did take the distributor out
Is there a certain way that it goes back in , ie markings.
The head gasket was changed due to oil leak at front & one at the back.
Car was not over heating or smokey.
make sure number 1 cylinder is on compression stroke TDC make a note of no1 spark plug lead postion on the distributor cap,remove cap. The rotor arm should be facing towards no1 lead on cap.If not turn the distributor until the rotor arm is facing no1 you can then fine tune using the timing gun once engine is running.
