Robbie Posted September 3, 2011 Share Posted September 3, 2011 I'm after a driveshaft for a manual tt . It's the pasenger side (short) and attaches to a diff (large casing version) Thanks Rob Link to comment Share on other sites More sharing options...
wile e coyote Posted September 4, 2011 Share Posted September 4, 2011 i got one mate it is off my tt but think they are all the same pm me the size and ill measure mine remember it does squeese in a bit when fitted, very easy to replace Link to comment Share on other sites More sharing options...
Robbie Posted September 4, 2011 Author Share Posted September 4, 2011 I'll measure it this morning and get back to you...Great, thanks! Link to comment Share on other sites More sharing options...
Robbie Posted September 4, 2011 Author Share Posted September 4, 2011 HI. I've not had a chance to measure it properly as its raining cats and dogs! Which bits should I measure it from/ to? Have you had a chance to measure drive shaft you have? Link to comment Share on other sites More sharing options...
mark newman Posted September 4, 2011 Share Posted September 4, 2011 I'm running standard TT drive shalfs from a small diff, on a large case diff . no problem at all. If I can remember the L/h side is 10mm smaller then the r/h . As you can see from my vids I do give the car stick, and on the drag strip, and if it was a problem it would have shown up by now. Link to comment Share on other sites More sharing options...
wile e coyote Posted September 4, 2011 Share Posted September 4, 2011 hi mate sorry but its the drivers side i have not passenger as this is the one i had to replace again sorry hope you get one, keron may have one Link to comment Share on other sites More sharing options...
Robbie Posted September 4, 2011 Author Share Posted September 4, 2011 Ahh, tis a shame! . how much would you want for it anyway? Link to comment Share on other sites More sharing options...
Robbie Posted September 4, 2011 Author Share Posted September 4, 2011 I'm running standard TT drive shalfs from a small diff, on a large case diff . no problem at all. If I can remember the L/h side is 10mm smaller then the r/h . As you can see from my vids I do give the car stick, and on the drag strip, and if it was a problem it would have shown up by now. I think the left and right shafts are quite a bit different in length on mine, more like 10 cm's than mm! Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 4, 2011 Share Posted September 4, 2011 http://www.mkivsupra.net/vbb/showthread.php?254111-drive-shafts Link to comment Share on other sites More sharing options...
Robbie Posted September 5, 2011 Author Share Posted September 5, 2011 http://www.mkivsupra.net/vbb/showthread.php?254111-drive-shafts Thank you Link to comment Share on other sites More sharing options...
keron Posted September 5, 2011 Share Posted September 5, 2011 na ones a lot of the time have a thinner shaft compared to the tt version...ive come across this a lot on them so worth checking... Link to comment Share on other sites More sharing options...
Robbie Posted September 5, 2011 Author Share Posted September 5, 2011 Hi Keron, I've bought these now.. oh well , I hope I've got the right one. I thought I'd try these any way. If it doesn't work out I'll probably be back in touch. Link to comment Share on other sites More sharing options...
Robbie Posted September 9, 2011 Author Share Posted September 9, 2011 na ones a lot of the time have a thinner shaft compared to the tt version...ive come across this a lot on them so worth checking... Yup. you were right. The shaft diameter is narrower than the Uk spec ones. Infact the na ones are 26.5mm as to my uk spec ones at 29mm I've taken the boot off one end to see how it works but I cant see any way of swapping the end casing over -which was what I was hoping for! Not sure where to go next on this... Link to comment Share on other sites More sharing options...
Robbie Posted September 9, 2011 Author Share Posted September 9, 2011 Still wanted! Link to comment Share on other sites More sharing options...
