Urgent: R33 GTR Single Turbo Downpipe
Jellybean
If it's part of a kit from a commercial kit maker, from the maker, if it's a one off you'll probably have to have one made.
Its this Spec Chris, it snaped at the turbo when trying to tighten the Cat :(
Model: Skyline R33 GTR 2.8L
Year: 1995/3
Grade:1
Interior Grade: B
Colour: Silver Metallic
Transmission:6 Speed Manual
Chassis:BCNR33-004516
Spec
Tune
  • FULL TUNE Engine Overhaul GTR Tuner - River Tec Racing of Japan
  • HKS 2.8L Kit Step 2
  • HKS Full Counter Crankshaft
  • Crankshaft Heat Treated
  • Crankshaft Balanced
  • Nismo Metal Bearings
  • Nismo Conrods
  • Trust Cams IN 256 / EX 264
  • Aftermarket Valve Guides
  • Nismo Engine Mount
  • N1 Block
  • Head Tuned
  • Metal Head Gasket
  • Apexi AX75F82 Single Turbo
  • Apexi Manifold
  • Apexi Downpipe
  • Screamer Pipe Extension
  • SARD Racing Wastegate
  • 720cc Injectors
  • Earls Type Fuel Lines and Connectors
  • SARD Fuel Delivery Rail
  • SARD Fuel Pressure Regulator
  • Ganador Racing Titanium Exhaust
  • Dual Engine Oil Coolers on Right / Left of IC (Secondary one controlled by Temp settings on FconV)
  • ARC Intercooler
  • Intercooler Hard Pipe Kit
  • 3 Core Radiator
  • Billion Header Tank
  • Apexi Fuel Pump
  • Collector Tank in Boot
  • HKS Induction Kit
  • One-off Metal Suction Pipe
  • Silk Road Engine Torque Damper
  • Silicone Radiator Pipes
  • Metal Oil Catch / Washer Fluid Tank
  • Reimax Clear Cam Cover
  • Adjustable Cam Pulleys
  • Nismo Oil Cap
  • Radiator Cooling Panel
  • R34 NUR Cam Covers
The chances of getting spares for Apexi turbo kits are all but zero, it'll have to be either repaired or another one made. Don't damage the turbo, they can't be rebuilt, they used a now obsolete bearing cartridge.
Thanks Chris, we are onto a fabricator over here just waiting on a price
Japfest is next Sunday; and Steven just taxed the car (you know it isnt cheap over here); the disappointment in his voice when he rang me, like he lost the will to live
Jellybean to the rescue ha ha, nothing a beer cant cure!
