sdistc Posted September 29, 2011 Share Posted September 29, 2011 Wow, didn't see this thread - thanks to both Ryan (for potentially losing some cash, but still staying true to the deals) and Rob (for helping everyone out by stepping up!). Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted September 29, 2011 Share Posted September 29, 2011 picking mine up saturday, cant wait.. not that i can do anything with it but it will make a nice ornament Link to comment Share on other sites More sharing options...
Ryan.G Posted October 4, 2011 Share Posted October 4, 2011 All units went out yesterday that requested to be shipped Link to comment Share on other sites More sharing options...
AlexM Posted October 4, 2011 Share Posted October 4, 2011 Lovely, thanks Ryan. Link to comment Share on other sites More sharing options...
Stonkin Posted October 4, 2011 Share Posted October 4, 2011 Sorry to hijack the thread Ryan, just wondering if there is anyone that has purchased a Syvecs from this group buy and will have an emanage ultimate that they no longer need? If so, please let me know. Link to comment Share on other sites More sharing options...
Ryan.G Posted October 5, 2011 Share Posted October 5, 2011 Gents, With the syvecs i would recommend the following sensors are fitted to make the engine well monitored and maintained. High Priority: Oil Pressure - http://www.efi-parts.co.uk/index.php?productID=243 Fuel pressure - http://www.efi-parts.co.uk/index.php?productID=243 NTK Wideband Lambda - Syvecs has in stock, Speak with [email protected] WIdeband Knock sensor - Syvecs has in stock, Speak with [email protected] Map Sensor ? Syvecs has in stock but cheaper here http://www.efi-parts.co.uk/index.php?productID=120 TPS Sensor ? Stock is fine Air temp ? Stock is fine Water temp ? Stock is fine Oil Temp- http://www.efi-parts.co.uk/index.php?productID=125 Optional Egt - http://www.efi-parts.co.uk/index.php?productID=175 AutoBox temp - http://www.efi-parts.co.uk/index.php?productID=125 If you get the above fitted just run the wires down to ecu and i will wire in and then setup the following safety trips, features and warm up limps. Oil Pressure drop - Cut engine or Limp mode Fuel pressure drop on boost i.e, Faulty pump - Will trim fueling to 15% then after that put in limp mode Map Limit cut - 1ms cut if an overboost event occurs Water temp - Does not allow over 4500rpm until water temp is over 65c also if water temp goes above 110c it limps engine. Oil Temp - Does not allow over 4500rpm until oil temp is over 70c also if oil temp goes above 135c it limps engine. Knock control - constantly monitors every cylinder and reduces timing in event on knock on that cylinder, if knock control pulls more than 10degrees shuts cylinder down. If more than 4 degrees timing is pulled Engine check light is lit. Egt - If temps go over certain temp fueling is trimmed also when using TC, Antilag or launch if temp gets to hot it turns off Ryan Link to comment Share on other sites More sharing options...
kwalker705 Posted October 5, 2011 Share Posted October 5, 2011 Ryan. At the moment i have oil temperature and oil pressure sensors fitted to the car for use with the oil press and oil temp gauges. Can these be utilised by the syvecs too ?? Or would you prefer the suggested sensors were used instead/also ?? Link to comment Share on other sites More sharing options...
sdistc Posted October 5, 2011 Share Posted October 5, 2011 Thanks Ryan. Only question for me is whether a 3 bar MAP sensor will provide enough headroom for mapping (last setup was to 32 psi on race fuel)? Link to comment Share on other sites More sharing options...
Ryan.G Posted October 6, 2011 Share Posted October 6, 2011 Ryan. At the moment i have oil temperature and oil pressure sensors fitted to the car for use with the oil press and oil temp gauges. Can these be utilised by the syvecs too ?? Or would you prefer the suggested sensors were used instead/also ?? Hi Keith I would suggest selling the gauges bud and then buying just the sensors which can be feed into the ecu. If you want to keep the gauges then it depends what gauges you have to wheather i can T into the sensor feed. The oil temp is a no for sure as the input loading on the Ecu which change the reading on the gauge. Ryan Link to comment Share on other sites More sharing options...
Ryan.G Posted October 6, 2011 Share Posted October 6, 2011 Thanks Ryan. Only question for me is whether a 3 bar MAP sensor will provide enough headroom for mapping (last setup was to 32 psi on race fuel)? Fear not! we have 4bar Map sensors in stock at Syvecs but they are abit more costly at £100 Link to comment Share on other sites More sharing options...
sdistc Posted October 6, 2011 Share Posted October 6, 2011 Fear not! we have 4bar Map sensors in stock at Syvecs but they are abit more costly at £100 Gotta pay to play Emailed Charlie already Link to comment Share on other sites More sharing options...
Dim Sum Posted December 4, 2011 Share Posted December 4, 2011 Is this group buy still available? Link to comment Share on other sites More sharing options...
Ryan.G Posted December 4, 2011 Share Posted December 4, 2011 Is this group buy still available? Now ended sorry Link to comment Share on other sites More sharing options...
mwilkinson Posted December 23, 2011 Author Share Posted December 23, 2011 Mods can this thread be locked please. As above this group buy is finished. Might be worth keeping the list of sensors that Ryan suggests above for reference though? Link to comment Share on other sites More sharing options...
