shell 10w40 ok? TT
k9l3
I use fuchs 10-40 semi-synth lots with Supras run it and even a chap who races Supras told me to go for it....he said it performed better on track than most of the other oils he has used...something about its better with Heat and takes longer to heat up and degrade something like that anyway....and its dirt cheap with Opie Oils I did the last oil change with it including oil filter for £24
well I thought use the same brand in 5 40 would balance it out a little . its a 96
mate shell oils are one of if not the best out there i have ran nothing but shell ultra in my supra and have 250+k miles on my accord using same oil, the h7 10w 40 is semi i personally wouldn leave it in supra any longer then 5k.
how do you find the 350gt ?
Is that an oil?
Seriously though, now i have got used to no turbo, its a dam good car, you can drive it like, and be as comfortable as any modern car, and also drive it like you stole it, and its still rewarding, not quite agile as a well set up Supra, but i am just about to have the geometry re done so ill let you know.
