95supra Posted September 1, 2011 Share Posted September 1, 2011 I'm getting my clutch done and need to get some oil. what grade of brake fluid is needed? thanks Quote Link to comment Share on other sites More sharing options...
caseys Posted September 1, 2011 Share Posted September 1, 2011 http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine But just to clarify for me... brake fluid? You mean for the brakes there yes? If so Motul RBF600 would be good But I would also check what you have in it currently, as some dot formulae do *not* mix with others. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted September 1, 2011 Share Posted September 1, 2011 I'd assume he means clutch fluid as he is doing the clutch. However clutch fluid is brake fluid and so it should be Dot4 minimum. If you have upgraded your actual brake fluid to a 5.1 then it is fine to use the same stuff as clutch fluid if you flush the system. Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 1, 2011 Share Posted September 1, 2011 If your doing the brakes vaccum bleed the whole system unless its been done recently Do not use DOT 5 as its silicon based and doesn't mix with DOT 3, 4 or 5.1 Quote Link to comment Share on other sites More sharing options...
