Rob_Mitchell Posted August 31, 2011 Share Posted August 31, 2011 (edited) Just a quick one.... will i get a 355mm disc under my 18" rims, the design of my wheel worries me as the inside sort of goes in a bit more, is there a template or something i could print out? regards Rob Edited August 31, 2011 by Rob_Mitchell (see edit history) Link to comment Share on other sites More sharing options...
JamieP Posted August 31, 2011 Share Posted August 31, 2011 Looking at that picture id say its very unlikely, welcome to try one of your wheels on my car, mine are 356 iirc Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted August 31, 2011 Author Share Posted August 31, 2011 Thanks mate i might hold you to that. im thinking of buying the greddy brakes in the forsale section but im worried they wont fit Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted August 31, 2011 Author Share Posted August 31, 2011 Anyone else have any ideas or have these size discs fitted... pics will be handy Link to comment Share on other sites More sharing options...
Josh Posted August 31, 2011 Share Posted August 31, 2011 Get the sizes and offsets of the wheels and that up for a better response. I can't help, but just sayin'! Link to comment Share on other sites More sharing options...
Bailey. Posted August 31, 2011 Share Posted August 31, 2011 I think paul has templates of the KAD brakes he sells if that helps?? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted August 31, 2011 Author Share Posted August 31, 2011 Get the sizes and offsets of the wheels and that up for a better response. I can't help, but just sayin'! 356mm should go with a 18" rim but its the design of mine im worried about! Link to comment Share on other sites More sharing options...
gjp Posted August 31, 2011 Share Posted August 31, 2011 K sport may fit! http://www.mkivsupra.net/vbb/showthread.php?206375-K-Sport-Brake-Kits&highlight=sport Link to comment Share on other sites More sharing options...
manny Posted August 31, 2011 Share Posted August 31, 2011 StopTech have templates on their website, they're specific to their kits but should give you a rough idea: http://www.stoptech.com/tech_info/wheel_fitment.shtml Link to comment Share on other sites More sharing options...
David P Posted August 31, 2011 Share Posted August 31, 2011 (edited) If it helps, those Ruff wheels clear U.K, calipers with about 3mm to spare. Edited August 31, 2011 by David P (see edit history) Link to comment Share on other sites More sharing options...
scoooby slayer Posted August 31, 2011 Share Posted August 31, 2011 greddy grex brakes are awesome, got 380mm 8 pots on mine and they are by far the best brakes i have ever had. Link to comment Share on other sites More sharing options...
hodge Posted August 31, 2011 Share Posted August 31, 2011 I had 356mm discs and 8 pots with 18" wheels I needed a 3mm spacer so it would clear the caliper. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted September 1, 2011 Author Share Posted September 1, 2011 looks good if they will clear uk spec then, i think it will be tight mind Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 1, 2011 Share Posted September 1, 2011 I have a template for K-Sport I can email you if needed? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted September 1, 2011 Author Share Posted September 1, 2011 ill drop you a line if needed paul, thankyou though. Link to comment Share on other sites More sharing options...
_Shane_ Posted September 1, 2011 Share Posted September 1, 2011 I had 356mm 8pot D2's on my supra with the do luck double sixes and it looked like they wouldnt fit either due to the design of the wheel but in fact they did, had a few mm to play with Happy days Link to comment Share on other sites More sharing options...
Paul372 Posted September 1, 2011 Share Posted September 1, 2011 try your wheels on my old mans supra while it's uo there to see if your wheels will clear uk spec brakes Link to comment Share on other sites More sharing options...
