Maximum Boost
Vaughany
I have just had a PHR Stage 1 kit (similar to Boost Logic T61) fitted that is running and has been mapped at a maximum of 1.4bar. My question is can I raise the boost to say 1.5/1.6bar on Optimax or is this to high for 98 octane fuel.
My fuelling is spot on at 1.4bar and also have water injection that will help prevent detonation and keep temps down. Also i suppose I could add an octane booster when I want to run more than 1.4bar.
The car is awesome at 1.4bar but was wandering if I could run higher boost on occasion. My Supra is an Auto so the transmission is probably handling all it can but I have added a transmission cooler to help keep the fluid cooler.
What is everyone else running on a Single Turbo with 98 octane fuel?
It's not cut'n'shut.
Depends on compression ratio, ignition timing, cam timing, intercooling and others (and that's just for engine durability)
To decide for the turbo itself one would need to look at the compressor map, or else would be guesswork...
[30psi boost is quite a stretch for most turbos, even if you run race fuel and manage to avoid detonation in the engine]
Guest Usmann A
youd have to roughly work out howmuch CFM the motor would flow at your chosen boost level, and then look at the pressure ratio you intend to runm and see in what sort off effieincy % the compressor runs at?
its mostly all guess work as to REALLY work out howmuch CFM the motor ingests we start talking about long long calcs ... and VE, which some of the AEM guys can get by just looking at thier fuel tables ... ;)
Anyway, if you need to convert CFM to lb/min its CFM*.76(at sea level) to give you a =lb/min.
its roughly like this ...
183 cid/1728= .1059 cubic feet of displacement
7100 rpm /2 = 3550 cylces per min
3550 cycles* .1059 = 375.94 CFM
375.94* 99%VE = 372 CFM
to get Pr(pressure ratio), gauge boost+14.7/14.7 = pressure ratio.
I hope this helps you understand when looking at comp maps, although ive left out loads of variables, like temp rise,boost,adiabatic effic,IC eff,density ratio, etc ,etc. but to get those all correct and in real time is something im working on. :)
HTH
Guest Usmann A
mm, John, that is the info needed to look at any comp map. ROUGHLY :)
Its good to know:)
I thought id explain to our dear member"Vaughny" on how comp maps work, very simple. its a tech section, and info is taken and given. :)
I expect that little post to be on your website, along with the collection of other peoples stuff. :)
May I call you copy and past king from now on John. :D
not really, why would you think that I'd copy your post and pass it as mine? (or whatever?)
If I feel the need to explain these things I can do it myself, can't I?
...along with the collection of other peoples stuff. :)
I do have lots of links to whatever I see as relevant or interesting. That's the whole idea of the internet, we don't need to reivent the wheel
Not really, if you think that I created my site using cut and paste you are grossly mistaken mate.
If text was taken from another source it's always credited (if it cannot be linked) and usually it's in different font/colour.
Guest Usmann A
lighten up John, its not nice when someone starts to bitch is it#?
I suggest you come off your high horse,as your atitiude simply comes across rather appauling sometimes,I didnt like the way in which you answered my post,it wasnt aimed at you. So, who are you to question it?
Ive seen you post countless times on stuff not appilcable, but I dont go out my way to say, "oooo this, ooo that".
Evethough you being my senior, I suggest you grow up stop playing grandad "know it all " of the BBS.
You are not the only one that knows about tuning, I see you have conflict with nearly everyone of the techies on this site.
I wonder why.
Now have fun ... :) ..... I know I will ....
what high horse dude, are you for real?
..as your atitiude simply comes across rather appauling sometimes,
well if I propose to you, don't marry me :limp:
I don't know it all mate.
If I did I wouldn't need to be here and learn from others.
I know that my internet 'persona' is kinda annoying sometimes, I can't help it though. It's not how people find me face to face - I blame the faceless internet :complain: .
That's why I added the last bit in my signature to account for this :giveup: .
Gentlemen, I thank you both for your info and expertise. My knowledge is not that in-depth so I think I read up a bit more and try to collate a variety of opinions.
In simple terms, I was hoping that someone would be able to say yes you can, no you cant and even better than that actually give examples based on their own experience.
I feel my mods cover everything safety wise but I am not sure. For example
I have
PHR Stage 1 Kit
HKS Type R Intercooler
Mocal Oil Cooler
Mocal Transmission cooler
650cc Injectors and all other main stream fuelling mods
Water Injection
I apologise for my ignorance but I thought it was to do with the octane rating hence everyone uses race fuel when they are running very high boost.
Anyway, thanks again now please CHILL OUT! :rolleyes:
Guest Usmann A
well, I don trun more than 17 psi on my 74, on 93USmon fuel(optimax) on moderate timing.
Sorry for the drama. :)
edited, i noticed its a 61mm, if so then I know guys running 1.6 bar, but thier using methanol, and fully mappable EMSs.
I cant comment on personal experience, but I know friends of mine who run 61s at around 1.3+ bar on pump fuel ... anything over 1.7 and I think it gets out of its ideal efficiency range ... but id need a comp map to check that.LOL
ive got all of PTEs comp maps on my laptop which is not with me, but if no one can get you it by monday, ill post it up. :)
PHR stage 1 is a GT67 right? if so, and it runs a .81hotside, ive got comp maps for that on my PC somewhere, let me dig them out.
even if not, you'll be fine for running over 1.5 bar easy pesy on a 67mm.
Yeeeeeeees! thats great (as I have a T61!) :clap:
Hello B'have I noticed you are running te same kit as myself, what boost pressure are you running and have you had he car dynoed. Just interested to see what results you have had.
Usmann A - I am fairly sure the stage 1 is a GT60
Hi Vaughany, yes, fitted the PHR kit 3 years ago.
Im not going above 1.5 at the mo as the SAFC is maxing out on 550 inj+FSE @ 40psi static. Have some 650's here for when i go e-mange ultimate or motec :tempted:
Hello Mate, I noticed your sig states 103 race fuel, is this what you are running at 1.5Bar. I am currently running a maximum of 1.4bar on 650cc with Emanage and my Dyno Graph shows my fuelling as spot on.
I was going to increase the boost a bit and use the water injection to compensate so I dont get any det but I was unsure if this is safe on 98octane.
Supraforums had a thread stating safe boost pressures on certain grades of fuel but unfortunately all there numbers seem to be different and they are quoting RON etc.
You can run silly boost pressures on SUL if water injection is set up accordingly, but I wouldn't exactly call it 'safe'
You're playing with fire, any failure in the W.I. circuit will end up in tears. At the very least you'd need a flowmeter (Aquamist do one that acts as a sensor - produces 0-5V depending on fluid flow)
I've seen it, and frankly can't think how it can really be of any use. There are so many variables involved that it is meaningless if you haven't got the same setup as it assumes.
You'd need knock monitoring if you start pushing the envelope towards DetLand.
Vaughney - it varies slightly from setup to setup mate. Some people can't run more than 1.4bar, some people can, but probably not *much* more. Intercooling is a big factor as well as octane, and compressor efficiency at that CFM flow (not *quite* boost pressure as it takes engine speed into account, thanks for the earlier explanation Usmann) as these are all factors in keeping the charge temps down to stave off det. I know a T61 that detted at 1.4bar and needed timing pulled to even stand a chance, even that was marginal and that's on a cold day with some moisture in the air! I also know a T67 that could run 1.4bar on a hot dry day with no timing pulled.
However, if your car has been mapped for 1.4bar then I really wouldn't take it above that :) Your tuner will have monitored AFRs, and started off nice and rich and sorted the ignition timing out and be listening for det... Except they haven't done any of that for more than 1.4bar (well maybe a smidge more to allow for boost fluctuation). It may handle more boost in theory but it'd still need mapping to that boost level :)
-Ian
Thanks Guys - Ian are you still taking your Laptop to JAE? If possible and you have the time I would like you to download my current Emanage map. We have previously spoke about me bringing my Supra to you for tweaking?
Are you there on Sunday?
