hodge Posted August 29, 2011 Share Posted August 29, 2011 Hi guys I need to a 2nd rear diff mount to my car before it's dyno'd as it was an N/A nod only had 1. I've bought a new 1 from Mr.T and was wondering what you thought the best way of getting the mount in without removing the subframe and pressing it in. I was thinking of making a disc the size of the mount, with a hole in the centre, screwing some threaded bar through it into the diff with a nut on the end and pulling it in as I tighten the nut up. What do you think??? Thanks John Quote Link to comment Share on other sites More sharing options...
hodge Posted August 30, 2011 Author Share Posted August 30, 2011 Any thoughts ??? Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 30, 2011 Share Posted August 30, 2011 Yes that could work Quote Link to comment Share on other sites More sharing options...
David P Posted August 30, 2011 Share Posted August 30, 2011 That would only work if you use a large and strong 'washer' to put the pull outside the rubber on the metal surround. I used a flat piece of 1/2" steel and a hammer to fit mine. Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 30, 2011 Share Posted August 30, 2011 I have a bearing race and seal driver set which goes up to 80 mm diameter, the driver rings are aluminium but their over 1/2 inch thick which should easily do the job. What diameter are the rear bushes ? Quote Link to comment Share on other sites More sharing options...
JamieP Posted August 30, 2011 Share Posted August 30, 2011 If you are making a disc up anyway I'd just weld that in place and solid mount the diff. Quote Link to comment Share on other sites More sharing options...
David P Posted August 30, 2011 Share Posted August 30, 2011 I have a bearing race and seal driver set which goes up to 80 mm diameter, the driver rings are aluminium but their over 1/2 inch thick which should easily do the job. What diameter are the rear bushes ? One of them should do it. Quote Link to comment Share on other sites More sharing options...
hodge Posted August 30, 2011 Author Share Posted August 30, 2011 If you are making a disc up anyway I'd just weld that in place and solid mount the diff. I did consider this to be honest but thought it better to have some flex in the to reduce transmission noise. The clutch does my head in so don't want to add to the heart ache. Quote Link to comment Share on other sites More sharing options...
hodge Posted August 30, 2011 Author Share Posted August 30, 2011 That would only work if you use a large and strong 'washer' to put the pull outside the rubber on the metal surround. I used a flat piece of 1/2" steel and a hammer to fit mine. Did you remove the petrol tank and Anti-roll bar or leave them in place. Quote Link to comment Share on other sites More sharing options...
David P Posted August 30, 2011 Share Posted August 30, 2011 I just dropped the centre of the ARB. Quote Link to comment Share on other sites More sharing options...
hodge Posted August 30, 2011 Author Share Posted August 30, 2011 I just dropped the centre of the ARB. Got ya. I'll give it a go Friday I think. Quote Link to comment Share on other sites More sharing options...
