injector question, low/high impedance?
mattysupra
Hi.
Im confused. What injector do i need for a Jap spec supra. i have high flow rail etc and im looking for around 1000cc injectors. But do i need high or low impedance injectors?
Or can i buy something to go with the injectors maybe so i can use which ever?
Thanks in advance
Most ecu`s will work with high impedance, you can use low impedance injectors and a resistor pack.
Thanks for the reply.
Im still lost tho. Does the jap spec have a resistor pack or not ? which ones do i need on my Jap spec car running a HKS FCON Pro ECU?
Why does the supra have a option of high or low impedance injectors?
:blink:
No one has actually answered the question directed.
I have been adviced i can get a resitor pack but for what? high or low impedance injectors!
Again i will ask a direct question, please forget fitting a resistor pack or of i have a resistor pack or not.
ON A JAP SPEC SUPRA WHAT INJECTORS DO THEY USE? high or low impedance?
Please correct me here but out of all the replies above no one has answered this question or am i being stupid here?
Imi answered it ;)
UK has a resistor pack Jspec doesnt :)
-> Stock ECU takes only High Impedance then.
He may of answered it for someone knowing if i need a resistor pack with high/low impedance injectors. But is till dont know which injectors go with the injector pack!!! But my question is what injectors does a Jap Spec use?
o.k i will ask the question different. I have a jap spec supra. I also have a set of 1200cc injectors that are high impedance. Do i need a resistor pack or not? can i use teh high impedance injectors in my supra or do i need a resistor pack with them as they are high impedance?
Stock injectors
UK Spec 550cc side feed/low impedance/includes resistor pack.
J-spec 440cc side feed/high impedance.
Most aftermarket rails fit top feed injectors, it doesn't matter if you fit high or low impedance injectors. If you fit low impedance injectors you will also need to fit a resistor pack, if you fit high impedance injectors you do not need a resistor pack.
According to the HKS website, the FCON can handle both low and high impedance injectors. The Internet is a wonderful thing.
Just to add to this thread incase someone else search's and arrives here.
I have found this in the Manual that states a Resistor is needed. You cant use low impedance injectors without the resistor.
