mattysupra Posted August 29, 2011 Share Posted August 29, 2011 Hi. Im confused. What injector do i need for a Jap spec supra. i have high flow rail etc and im looking for around 1000cc injectors. But do i need high or low impedance injectors? Or can i buy something to go with the injectors maybe so i can use which ever? Thanks in advance Quote Link to comment Share on other sites More sharing options...
bignum Posted August 29, 2011 Share Posted August 29, 2011 Most ecu`s will work with high impedance, you can use low impedance injectors and a resistor pack. Quote Link to comment Share on other sites More sharing options...
mattysupra Posted August 29, 2011 Author Share Posted August 29, 2011 Most ecu`s will work with high impedance, you can use low impedance injectors and a resistor pack. Thanks for the reply. Im still lost tho. Does the jap spec have a resistor pack or not ? which ones do i need on my Jap spec car running a HKS FCON Pro ECU? Why does the supra have a option of high or low impedance injectors? Quote Link to comment Share on other sites More sharing options...
imi Posted August 29, 2011 Share Posted August 29, 2011 No it doesnt, the UK one however does. Quote Link to comment Share on other sites More sharing options...
mattysupra Posted August 29, 2011 Author Share Posted August 29, 2011 No it doesnt, the UK one however does. So i need high resistance injectors then on my Jap Spec? Quote Link to comment Share on other sites More sharing options...
imi Posted August 29, 2011 Share Posted August 29, 2011 you can always fit a resistor pack to a Jspec if needed. Quote Link to comment Share on other sites More sharing options...
mattysupra Posted August 29, 2011 Author Share Posted August 29, 2011 does anyone have a defo answer for me please. We seem to be going around in circles. Simple question, what injectors do i need to purchase for a JAP SPEC supra. Do i need high or low impedance please? Quote Link to comment Share on other sites More sharing options...
imi Posted August 29, 2011 Share Posted August 29, 2011 does anyone have a defo answer for me please. We seem to be going around in circles. Quote Link to comment Share on other sites More sharing options...
heckler Posted August 29, 2011 Share Posted August 29, 2011 It all depends on the ECU... I'm not sure about what the FCON one can drive. Some ECU can handle both types of injector Quote Link to comment Share on other sites More sharing options...
heckler Posted August 29, 2011 Share Posted August 29, 2011 According to the HKS website, the FCON can handle both low and high impedance injectors. The Internet is a wonderful thing. Quote Link to comment Share on other sites More sharing options...
mattysupra Posted August 29, 2011 Author Share Posted August 29, 2011 No one has actually answered the question directed. I have been adviced i can get a resitor pack but for what? high or low impedance injectors! Again i will ask a direct question, please forget fitting a resistor pack or of i have a resistor pack or not. ON A JAP SPEC SUPRA WHAT INJECTORS DO THEY USE? high or low impedance? Please correct me here but out of all the replies above no one has answered this question or am i being stupid here? Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted August 29, 2011 Share Posted August 29, 2011 No it doesnt, the UK one however does. Imi answered it UK has a resistor pack Jspec doesnt -> Stock ECU takes only High Impedance then. Quote Link to comment Share on other sites More sharing options...
mattysupra Posted August 29, 2011 Author Share Posted August 29, 2011 According to the HKS website, the FCON can handle both low and high impedance injectors. The Internet is a wonderful thing. Thankyou. So with a hKS ECU i dont need to worry. but do we know what injector the jap spec uses as stock? Quote Link to comment Share on other sites More sharing options...
heckler Posted August 29, 2011 Share Posted August 29, 2011 The FCON can drive either types without a resistor pack, so doesn't matter which you go for! Quote Link to comment Share on other sites More sharing options...
heckler Posted August 29, 2011 Share Posted August 29, 2011 IIRC Jap are high impedance, hence no resistor packs Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted August 29, 2011 Share Posted August 29, 2011 Yes they are high impedance ^^ Quote Link to comment Share on other sites More sharing options...
mattysupra Posted August 29, 2011 Author Share Posted August 29, 2011 Imi answered it UK has a resistor pack Jspec doesnt -> Stock ECU takes only High Impedance then. He may of answered it for someone knowing if i need a resistor pack with high/low impedance injectors. But is till dont know which injectors go with the injector pack!!! But my question is what injectors does a Jap Spec use? o.k i will ask the question different. I have a jap spec supra. I also have a set of 1200cc injectors that are high impedance. Do i need a resistor pack or not? can i use teh high impedance injectors in my supra or do i need a resistor pack with them as they are high impedance? Quote Link to comment Share on other sites More sharing options...
mattysupra Posted August 29, 2011 Author Share Posted August 29, 2011 question answered, thanks the above two ! F-me that was hard. Thanks again Quote Link to comment Share on other sites More sharing options...
Nic Posted August 30, 2011 Share Posted August 30, 2011 Stock injectors UK Spec 550cc side feed/low impedance/includes resistor pack. J-spec 440cc side feed/high impedance. Most aftermarket rails fit top feed injectors, it doesn't matter if you fit high or low impedance injectors. If you fit low impedance injectors you will also need to fit a resistor pack, if you fit high impedance injectors you do not need a resistor pack. Quote Link to comment Share on other sites More sharing options...
mattysupra Posted August 31, 2011 Author Share Posted August 31, 2011 According to the HKS website, the FCON can handle both low and high impedance injectors. The Internet is a wonderful thing. Just to add to this thread incase someone else search's and arrives here. I have found this in the Manual that states a Resistor is needed. You cant use low impedance injectors without the resistor. Quote Link to comment Share on other sites More sharing options...
