Drag car braking for spares
dude
OK guys let the scavenging begin, some bits may be kept, those will have an exclamation next to them, the rest can go as plans have massivly changed:eyebrows:
Borg warner Airworks turbo kit,virtual works manifold and twin wastegates, good for 1300hp, T6 based, Already run 7 sec 1/4 £4000
Full race Inlet Plenum, 4" TB and direct port NOS kit (hidden underneath) 10lbs bottle and all lines/solenoids £1000
4" Twin box exhaust from DP back SS with burns back box 5" TP with bung £500
5" Custom FMIC and pipework 3" in 4" out dropped temp 40 degrees on the dyno £800
CO2 FMIC cooler and 2/3 bottles £300
280 duration 10.4 Titan cams £400 !!!
280 duration 9.8 SRD Inlet cam £200
Jun pulleys £300
Billet timing bracket £100
AEM version 1 £750
Breather kit inc polished cam covers, -12 lines, tank, K&N filters and -12 line to DP (you will need 1 way valve) £450
FMIC and rad panel £30
Rear lights and C west tinted covers £150
Bomex front bumper (been repaired) £150
Bitz rear bumper and side skirts £400
Steering wheel with 4 switches for horn, line lock, CO2 and NOS purge, with hub and loom £100
D2 coilovers £400
Titan Big Boy Carbon prop £1000
Scattershield £200
ORC 4 plate clutch and flywheel (laughs at 1000hp) £1400
6 spd conversion with UK 6 spd - clutch and flywheel £2500
Stillway shifter kit to convert your shifter X 2 £200 each
Strengthened rear subframe with solid diff mounts and super strong 90mm studs (cost me £575 for studs) £350 !!!!
8 gall fuel cell, aeromotive pump, -12 lines, twin regs, guages, mixer pots, filter (will support 1500hp) £1400
Parachute, bracket and rear crash bar mount, inc release handle and cable £250 !!!!
SSR DeColte alloys 11 X 18 and 9 X 18 (I think) 295/35 rear, 264/40 front with alloy nuts (prob lightest road wheel around) £1000
10 X 15 Weld drag wheels with 3 sets 325/50/15 DR's 1 set new, 1 set loads left, 1 set for burnouts with nuts and locating rings £800
Corbeau kevlar bucket seats Pro Series £400
Luke harness's 1 year old, grey 3" + 1 older 21/2" £100
6 speed shell, flocked interior black carpet, black headliner Robinson 8.5 tagged cage £offers
Rod millen TRD rear spoiler, black pillars carbon blade £300
PHR solid engine mounts £100
More to come !!!!
Please use PM, I will try and be as fair as possible re who gets what etc, all parts can be fitted at cheaper than normal rate and are all plus p&p.
  • Replies 88
