Whats it worth
Guest lidborn
Guest lidborn
Small spec:
single Manifold
IC model large
dump
Ported and polished top
Precision pt67 turbo
Precision 1000cc injectors
Crower valve springs
Crower 264 cams
JE pistons
Eagle rods
ARP crank bolts
ARP cylinder head bolts
Clevite Bearing
Clevite Bottom Bracket
HKS wastegate
HKS adjustable cam wheel
HKS Timing Belt
HKS Fuel Rail
Veilside intake modified
Dual Walbro 255l fuel pump
Aeromotive fuel pressure regulator
AEM Air Filter
AEM P & P
PHR Ignition Cover
Modding oil pump
Oil Cooler Kit relokation
TRD engine mounts
Custom Made gearbox mount
Torque 4 "downpipe and midpipe then HKS 3 'rest
6 speed GETRAG
Spec flywheel
spec clutch
And more
HKS coilovers
Alu bracket to the differential
Euro Spec brakes front and rear with slotted discs and race pads
steel braided hoses
Zito Titanium 9.5 front and 11.5 rear painted in graphite with carbon-fiber edge
19 "11.5" rear 315/30/19 Dunlop GT
19 '9.5 "front 265/30/19
Tuning seat
Custom-made door panels
Painted dashboard and all interior
Painted panels at the steering wheel and gear in the same color as the car
The rear seat removed
Roll cage in stainless but painted
Molded box in the back seat with 2 Mutant XXX10 "
Mutant front and rear 3-way speakers
Kenwood DVD
Widebody hand made by me
Broadens 14cm rear and front 8cm
Modded front lights
Xenon 8000K and low beam LED lights dim o park lighting
Hidden side markers
Audi TT turn signal front
Tinted taillights
Welded the holes to the wing, wipers, brake lights and antenna
Problem is its drives on the "wrong" side for EU market (outside UK) hence it will be hard to get any good money for it in sweden/Germany. As thoose willing to pay that amount gets a nice eurospec (LHD) with a possible single turbo etc.
here in sweden i would never even consider buying a RHD supra for 20k, i bought mine for 8.350. Iam probebly going to rebuild my supra for LHD since that way i would actually raise the value of the car. and considering people in the UK have some super nice importers such as JM/Jurgen for 22k they would get a verry special supra from Japan.
That said.. its going to take some time for you to get this sold for that kind of money in a LHD contry me thinks.
