ksbkrew Posted August 28, 2011 Share Posted August 28, 2011 hello i'm making an auto to R154 swap for my Mk4! and i've got a question Do someone know exactly what size do i need to extend the shifter ? i'm using an auto tunnel, i found somebody who tells 2inches, some 4. What is exactly the size? thanks a lot Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted August 28, 2011 Share Posted August 28, 2011 I changed the tunnel on mine, and had it extended 150mm, using a w58 short shifter. Do a search on here for a guy called steve, in one of the r154 tt conversion threads, he extends them for 120 quid. Quote Link to comment Share on other sites More sharing options...
ksbkrew Posted August 28, 2011 Author Share Posted August 28, 2011 and when you change the tunnel , the dead center stay at the same point or it 's been moving? Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted August 28, 2011 Share Posted August 28, 2011 Cant say I checked, however my box wouldn't fit with the auto tunnel. Quote Link to comment Share on other sites More sharing options...
Homer Posted August 28, 2011 Share Posted August 28, 2011 I don't see how you'll be able to use the auto tunnel with the r154, the shifter mechanism will foul it, even at the front. It would make life much easier to drill out the auto plate and bolt in a new manual one. They're about £65 from Toyota, it's not difficult to do if the box is out. Quote Link to comment Share on other sites More sharing options...
ksbkrew Posted August 29, 2011 Author Share Posted August 29, 2011 i have just to cut out the auto plate and change by the manual one? Quote Link to comment Share on other sites More sharing options...
