Changing handbrake cable
Digsy
Before I get into a job I can't finish and ruin my Bank Holiday Monday completely, can anyone tell me what to expect when I try to remove the driver's side handbrake cable? I know how to detach it from the handbrake at the wheel end but what happens at the other end I don't know. I'd like an idea of what I will need to remove and any possible pitfalls. I can't say I've ever noticed the "T" joint between the three cables when under the car so I'm assuming its behind a heatshield or maybe above the driveshaft or something.
Thanks!
OK, done it. Not too bad to do. The T piece is above the driveshaft where the exhaust splits into two after the second cat. You can reach it without taking anything else off the car but it pays to let the exhaust cool down a bit unless you want burned wrists :) The screws holding the cable to the chassis (2x 8mm and 1x 6mm) looked like they would wring off but came out with just a squirt of WD40. The 2x 6mm screws holding the cable to the wheel hub both wrung off - luckily I had a couple more with my spare cable.
One thing to note, though, is that while replacing the RHS cable I spotted that the LHS one was also broken in exactly the same way. There is an aluminium casting at the wheel end of the cable which breaks as shown in the picture. When the RHS one broke it jammed the cable but on the LHS it hasn't yet, so it should be OK to get through the MOT next week.
Might be worth checking these on more elderly Supras.
