Rob_Mitchell Posted August 26, 2011 Share Posted August 26, 2011 hey guys i thought i would have a play today and mount my 2 srd gearbox coolers..... help! there is loads of room inbetween the intercooler and radiator but i cant decide where to take my mounting points from. what did you guys do? bearing in mind i have no air-con so cant mount the coolers to that. pics would come in handy. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted August 26, 2011 Author Share Posted August 26, 2011 I think i have a good idea what im doing now , ill update the thread with pics, might help others out in my situation Quote Link to comment Share on other sites More sharing options...
djg99 Posted August 26, 2011 Share Posted August 26, 2011 I put mine where the old SMIC went as changed to a FMIC plenty of space and air there! Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 26, 2011 Share Posted August 26, 2011 I'd go for either side of the fmic, plenty of room in my bumper, i'd fit a custom frame to bumper base with some hangers coming down from the frame the headlights sit on Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted August 26, 2011 Share Posted August 26, 2011 Put the coolers resting on the front plate the sits between the rad and the IC? As you are not running an aircon rad. Simply put a few nutserts into the transverse bit of chassis and sit them on it?? I believe Hodge put his Oil cooler there Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted August 26, 2011 Share Posted August 26, 2011 voila! Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted August 26, 2011 Author Share Posted August 26, 2011 [ATTACH=CONFIG]137973[/ATTACH] voila! yeah his coolers have decent brackets built in so you can mount them, the srd ones dont, making the brackets is easy but its attaching them to the coolers is going to be tricky as there is not much to mount the other end of the bracket to. Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 26, 2011 Share Posted August 26, 2011 yeah his coolers have decent brackets built in so you can mount them, the srd ones dont, making the brackets is easy but its attaching them to the coolers is going to be tricky as there is not much to mount the other end of the bracket to. How do they fit as i've looked on the SRD thread but its not very clear how you mount them Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted August 26, 2011 Author Share Posted August 26, 2011 I have mounted 1 cooler ontop of the other cooler like the pic, (not my car) but obviously i have no air con rad, i can make the brackets to come off the front panel but ANY ideas how i would mount the cooler to the bracket? securely!.. would tacking a weld/bracket to the frame of the cooler damage it? Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted August 26, 2011 Author Share Posted August 26, 2011 How do they fit as i've looked on the SRD thread but its not very clear how you mount them usually you mount the coolers to the air-con rad, really long rods push through the coolers and rad and its like a cable tie design to lock it all secure... bloody good design but i cant do it that way. the insructions show mounting using brackets but the tiny screws are not that strong and im worried they wont hold it. Quote Link to comment Share on other sites More sharing options...
