Lude Posted August 26, 2011 Share Posted August 26, 2011 ive got a replacement pipe to go from the PAS to the resivour, PVC, 16mm got a jubilee clip each end done up TIGHT. there is a bit of fluid still seaping thro tho i beleive, as the pump has some oil on. whats the best way/product to stop this? spoken to member who advised just put some sealer on the base of the pump where meets the pipe, (thanks again pedrosixfour anyone got any products/methods to cure this leak? Quote Link to comment Share on other sites More sharing options...
Scott Posted August 26, 2011 Share Posted August 26, 2011 I'm not meaning to sound cheeky here, although I know it will come across this way, but I always have a really tough time reading your posts. Is English your first language? The reason I ask is that it's easy to forgive if it isn't, but if it is then you are really lazy with your posting. Text 'speech' is also forbidden on the forum. Quote Link to comment Share on other sites More sharing options...
Lude Posted August 26, 2011 Author Share Posted August 26, 2011 (edited) I'm not meaning to sound cheeky here, although I know it will come across this way, but I always have a really tough time reading your posts. Is English your first language? The reason I ask is that it's easy to forgive if it isn't, but if it is then you are really lazy with your posting. Text 'speech' is also forbidden on the forum. sorry dude i do try to explain but its difficult when typing, havent used any txt speak in the post tho? if you can PM me where have etc rarther, as like to keep the thread on topic... nice1 EDIT: only way i can describe further is that i have joined the resivour to the pump, with new pipe. i have oil leaking where the pipe meets the pump, i have jubilee clipped the pipe to the pump, do other people use a special sealer to prevent the fluid dribbling out the pipe onto the pump.. Edited August 26, 2011 by Lude (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted August 26, 2011 Share Posted August 26, 2011 Done Quote Link to comment Share on other sites More sharing options...
Lude Posted August 27, 2011 Author Share Posted August 27, 2011 starting to think it could be the pump itself which is leaking, will do a test & report back, anyone had the AN fitting leak or can the pump itself leak? Quote Link to comment Share on other sites More sharing options...
David P Posted August 27, 2011 Share Posted August 27, 2011 Proper pipe needed methinks. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 27, 2011 Share Posted August 27, 2011 PVC is for flashers, a proper rubber hose a la Toyota OE is what you need, why would you choose PVC as a material for this pipework? Quote Link to comment Share on other sites More sharing options...
Paul Posted August 27, 2011 Share Posted August 27, 2011 PVC is for flashers, a proper rubber hose a la Toyota OE is what you need, why would you choose PVC as a material for this pipework? Cause he's Welsh, they're into PVC Quote Link to comment Share on other sites More sharing options...
scotty71 Posted August 27, 2011 Share Posted August 27, 2011 (edited) Is English your first language? does he look English with that beaten about the face with a raw fish mugshot?? havent used any txt speak in the post tho? if you can PM me where have etc rarther, as like to keep the thread on topic... nice1 Yep Nice one Edited August 27, 2011 by scotty71 (see edit history) Quote Link to comment Share on other sites More sharing options...
Lude Posted August 28, 2011 Author Share Posted August 28, 2011 (edited) Didn't realize that the pvc pipe would be incorrect, as it stated oil resistant, I've put some oil resistant sealer on it now to see if that holds it, what materiel is the OEM pipe? Will get some... Edited August 28, 2011 by Lude (see edit history) Quote Link to comment Share on other sites More sharing options...
heckler Posted August 28, 2011 Share Posted August 28, 2011 Didn't realize that the pvc pipe would be incorrect, as it stated oil resistant, I've put some oil resistant sealer on it now to see if that holds it, what materiel is the OEM pipe? Will get some... The OEM pipe is Nitrile butadiene rubber (NBR) - I only know as I have on sat in front of me at the moment! Quote Link to comment Share on other sites More sharing options...
Scott Posted August 28, 2011 Share Posted August 28, 2011 does he look English with that beaten about the face with a raw fish mugshot?? There are a couple of Pakistani guys near where I stay, they run the local shop. Both born and bred in Scotland and as Scottish as it gets when talking to them. Their first language is English bud. Can't judge people on their appearance Quote Link to comment Share on other sites More sharing options...
dude Posted August 28, 2011 Share Posted August 28, 2011 There are a couple of Pakistani guys near where I stay, they run the local shop. Both born and bred in Scotland and as Scottish as it gets when talking to them. Their first language is English bud. Can't judge people on their appearance Ive also spoken to scots and geordies and not understood a word they have said !!!!!! Quote Link to comment Share on other sites More sharing options...
Scott Posted August 28, 2011 Share Posted August 28, 2011 Ive also spoken to scots and geordies and not understood a word they have said !!!!!! The yanks are like that. They cant understand anything outside their own bubble either Quote Link to comment Share on other sites More sharing options...
David P Posted August 28, 2011 Share Posted August 28, 2011 Here's the hose you need, I paid £15.02 for mine from Mr T. 44348A HOSE, OIL RESERVOIR TO PUMP, NO.1 44348‑24040 Quote Link to comment Share on other sites More sharing options...
Lude Posted August 28, 2011 Author Share Posted August 28, 2011 cheers everyone, hope its just the pipe now & not the pump Quote Link to comment Share on other sites More sharing options...
