Front fog stopped working
sams
while checking over my car today i noticed my front fogs have stopped working(they used to work). but it caused the front side lights not to work. example; sidelights on front fogs off the sidelights (inc rears) work fine. main beam on fogs off all lights work fine. but as soon as i turn the front fogs on the front side lights go off and fogs dont work but all other lights work.
could this be the relay at fault? i have checked all the fuses in the engine bay fusebox and in the driver footwell. i have even checked the connection on each the bulbs but everything looks fine the only thing i can think it can be is the relay but would affect the front sidelights. my rear lights work fine on all options.
the rear fog is on it own wireing and switch and never been a problem
can anyone tell me how much the relay is likely to cost. it is the relay at fault. i turned on all the lights inc front fogs the sides were not working i pulled the fog relay out and they came on. i then bridged the terminals 3 and 5 marked on the relay as a switch and the fogs cam on. the details on the relay are
relay iso m4-s
toyota
90987-02010
156700-0060
12v
Denso
made in japan
